Old 07-27-2012, 02:04 PM
BAILEIGH INC's Avatar
BAILEIGH INC BAILEIGH INC is offline
Originally Posted by Revved View Post
Beautiful... How much?
http://www.baileighindustrial.com/me...mer-bf-035.php
Old 07-27-2012, 02:14 PM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Reviving an old thread looking for bead roller info...
I'm looking for something mostly for putting a bead on the end of tubing. Anyone have anything special they would recommend?
These work on aluminum.
http://www.summitracing.com/search/P...ubing-Beaders/
Old 07-27-2012, 02:21 PM
Revved's Avatar
Revved Revved is offline
Then of course the debate... spend $300 for this one or spend a little more and get one with a throat in case I decide to try rolling panels some day. I'm assuming this one can do tubing ends as well as handling panels?
http://www.baileighindustrial.com/me...r-br18M-24.php
Originally Posted by MarkM66 View Post
Interesting little tools... but the smallest I'm doing is 1 3/4 and up to 4"... some stainless but mostly aluminum.
Old 07-28-2012, 03:29 AM
MarkM66's Avatar
Here's a less expensive one by Jegs.
http://www.jegs.com/p/JEGS-Performan...23179/10002/-1
Old 07-28-2012, 12:27 PM
Revved's Avatar
Anybody used one of these? Ship date of 8/31-- over a month so may not even be available.
Old 07-28-2012, 05:46 PM
70 chevelle 70 chevelle is offline
If a bead roller is a possibility why not get this?
http://www.mittlerbros.com/index.php...eavy-duty.html
with this
http://www.mittlerbros.com/index.php...ad-roller.html
You will have a much more versatile set up as this will allow you to bead panels also. I ended up getting the 36 inch Mittler with the industrial motor and love it.
Tony L
You can't fix stupid!
Old 07-29-2012, 01:54 PM
Revved's Avatar
with this
Back to the question that I need to answer on whether I would use it enough to justfy the $600 price tag for the roller and die set. Right now the only thing I would use it for the forseeable future is rolling the ends of tubing as I really don't do much sheet metal work. If that JEGS roller was available it would already be ordered. Probably going to end up with the Baleigh tubing roller...
Thanks for the info guys!
Old 07-30-2012, 06:48 AM
Please note that anyone from this forum gets "special" pricing, just call me direct for the hookup. 920-482-3220
Old 07-31-2012, 08:57 PM
Northeast Rod Run's Avatar
Northeast Rod Run Northeast Rod Run is offline
TJ Ragucci
http://www.northeastrodrun.com/
Old 08-01-2012, 07:05 AM
We treat the forum guys quite well.
