Old 08-27-2011, 01:54 PM
69MyWay's Avatar
69MyWay 69MyWay is offline
Originally Posted by DarkoNova View Post
So the system didn't come with a trinary switch?
It will if you order it that way, otherwise it will just be a binary to trip the compressor clutch. That assumes you are running a mechanical fan.
Old 08-27-2011, 05:59 PM
DarkoNova DarkoNova is offline
Banned
So what's the trinary switch do that the binary switch doesn't?
I'm an a/c noob.
Old 08-27-2011, 07:48 PM
69MyWay's Avatar
I'm an a/c noob.
The binary is only to cycle the a/c clutch. It screws into the drier unit and if the pressure gets too low it will kick the clutch out.
The TRINARY does that...plus it will complete a ground loop to you fan relay when the a/c head pressure gets to 250kpa (don't quote me on that number).
That way, your electric fan does NOT run when you are going down the highway just because the a/c is on. It will only cycle the fan when it is needed.
If you don't have an electric fan on your radiator then you don't need the Trinary switch.
