Old 08-25-2011, 10:30 PM
Lenie's Avatar
Lenie Lenie is offline
Default Pics of Vintage Air Condenser/Drier
Please show pics of your vintage air condenser and drier mounted.
Lenie
Old 08-26-2011, 07:34 AM
69MyWay's Avatar
69MyWay 69MyWay is offline
Default ask...and you shall receive....
Old 08-26-2011, 09:21 AM
Lenie's Avatar
Originally Posted by 69MyWay View Post
That looks good, did you order all the hard lines from VA or did you bend yourself?
Lenie
Old 08-26-2011, 09:50 AM
Chad-1stGen's Avatar
Chad-1stGen Chad-1stGen is offline
Those hard lines look exactly like the ones VA supplies. There are three peices. The one between condenser and filter/drier is 100% hardline. The other two switch to rubber shortly after they pass under the core support.
Autocross and Track blog
Lots of autocross & track day videos of my car: https://www.youtube.com/user/TheDude023
Old 08-26-2011, 10:00 AM
69MyWay's Avatar
They came with the complete kit - fit like a glove.
What you don't see there is the trinary switch that I installed before charging the system. It kicks the electric fan on at 250kpa and cycles the compressor as long as it stays above a mimum level. The trinary is great because it keep sthe fan from running when you are going down the highway.
Old 08-26-2011, 08:37 PM
Lenie's Avatar
Thanks guys, I don't know anything about VA and air conditioning. First I've heard about a trinary switch, I'll have to look into it. Car came w/VA 2 in boxes and the bracket was already installed by DSE years ago which is still on their site so unless there's a big reason not to use the older model I'm going to stick w/it. It didn't come with compressor, condenser, drier or any of the lines so I need to add those items but first I need to research and know how to go about doing it. I added the march system package that had a compressor so now I'm moving forward from there. If any of you have helpful hints and pictures, I'm all ears and eyes.
Thanks again
Lenie
Lenie
Old 08-26-2011, 10:46 PM
Trinary is the only way to go.
Old 08-27-2011, 12:18 AM
TT302Z28 TT302Z28 is offline
When I bought the 70 Chevelle I had it came with a VA kit half way installed. Many parts were missing but VA was very helpful assisting me to determine what I needed.
Give them a call.
Old 08-27-2011, 04:50 AM
69MyWay's Avatar
Give them a call.
You can't beat their product - service - and performance!
I have the earlier model in my Camaro - no complaints. Still cools the car just fine, but it is a little more simple set up. I've since put the Magnum units in all the other projects. Very sophisticated and amazing, but at the end of the day it simply cools or heats the cabin which is what we crave.
I see no reason why you can't go with the Magnum style/Gen IV condenser, drier, and lines since both of them terminate on the firewall in about the same way. The only thing is you will have a custom length on the lines to the compressor since you are using the other brackets. No big deal, easy to modify.
Old 08-27-2011, 09:53 AM
DarkoNova DarkoNova is offline
Banned
So the system didn't come with a trinary switch?
