Old 06-03-2012, 07:50 PM
RECOVERY ROOM's Avatar
Supporting Vendor
RecoveryRoomInteriors.com
Originally Posted by skooli View Post
Thanks for the replies. I know it's not a high end build like some of the other cars on this forum, but I think it's going to turn out pretty solid.
High or low end, as long as your in the game. There all good
TRACY WEAVER
www.recoveryroominteriors.com
Old 01-10-2013, 10:15 PM
skooli's Avatar
skooli skooli is offline
Finally got my 383 from Blueprint Engines. The dyno sheet says 420hp @5500 rpm, and 450 lb/ft of torque.
Gonna finish cleaining up the intake manifold, painting the headers, paint the block Hugger Orange, and hopefully have it in the car in the next couple of days.
Brad
67 Camaro
383/ 700r4
57 F100
289 / C4
Old 03-03-2013, 02:45 PM
skooli's Avatar
Engine is finally in. Having the fender wells, hood hinges, and core support powder coated, replacing the brake booster/master cylinder with an SSBC set up, adding a quick ratio steering box and that should finish up the enigine compartment. It's only taken a year. Hopefully the rest of the project goes a little faster.
Brad
67 Camaro
383/ 700r4
57 F100
289 / C4
Old 03-03-2013, 02:54 PM
Congrats! The engine looks good in there. Good luck finishing the rest.
Old 03-03-2013, 04:11 PM
coolwelder62's Avatar
Those blueprint engine's seem like a deal.
Old 03-03-2013, 04:45 PM
Cole Cole is offline
Banned
Whats the combo on that 383?
Old 03-11-2013, 01:14 AM
skooli's Avatar
It's a 4 bolt main block with one piece rear main.
Flat tappet cam (.480 Int / .486 Exh & 229 Int / 230 Exh duration @ .050)
Blueprint 195cc aluminum heads
Here's the link to the page on their site:http: //www.blueprintengines.com/index.php/gm-383-bp3834ct1
Brad
67 Camaro
383/ 700r4
57 F100
289 / C4
Old 11-21-2013, 09:54 PM
skooli's Avatar
Well there's been some progress, but the real world has intervened and turned this into more of a budget build than I planned for. It's going to be more of a mild resto-mod than a pro-touring car. The original plan was to use a Currie 9" but the budget has led to me rebuilding my 12 bolt. I tore it down and it was in pretty good shape with Richmond 4.11s an Eaton Posi and Strange C clip Eliminators. It needed new bearings so I ordered new C clip eliminators from Strange. Unfortunately that means no disc brakes so I went with drums from Classic Industries. At least they're better than the old rusty brakes. I cleaned and painted the housing and now it's ready to get back under the car.
Brad
67 Camaro
383/ 700r4
57 F100
289 / C4
Old 11-21-2013, 10:00 PM
skooli's Avatar
Well it's back on the wheels, but I'm under a time crunch because I'm moving to the mainland. So no time for paint or body work. I did get my new front fascia on so I'll have front turn signals. I'll have to paint it when I get settled in to our new place. Here's some new pics.
Brad
67 Camaro
383/ 700r4
57 F100
289 / C4
Old 11-22-2013, 04:59 AM
Rick D's Avatar
Rick D Rick D is offline
Looking good, there's nothing wrong with a buget build!! I hope you do not have to move all of those cars in your garage??
Rick
