Old 03-04-2012, 07:51 PM
chicane's Avatar
chicane chicane is offline
Uhm, actually... Rockland Standard Gear is who builds the "Transzilla"... NOT RPM. (Your point of contact at Rockland Standard will be George Kreppin.)
If you are after a 'dog ring' gear box... both of the transmissions available from RSG and/or Keisler have that option. The gear sets from Keisler, in my opinion are much better than the welded faceplate design that the RSG Tranzilla utilizes.
However, if your after a standard synchro set up... they are both the same.
The real question is what your final gear ratio will/should be. The fact that any driven OD gear of 0.75 or more, will dictate a huge drop in efficiency. So I would think that a final ratio of around 2.50:1 would be choice.
The first gear final ratio is also important... and it is better to keep that as close to around 8.0:1 to about 10.0:1. So just keep that in mind when selecting the transmission ratios available.
Old 03-04-2012, 10:16 PM
69/RS 69/RS is offline
The car will have remote reservoir double adjustable coil overs so it will be set up for road racing but will be a nasty street car for the most part. I like to over engineer because I don't want problems at a later point in time. I just want to make sure that what ever set up I get, it will be able to handle the power and not blow up weather I'm at the drag strip, road race or mashing on the street.
Originally Posted by 454SSguy View Post
All I know about RPM trans is they build the Tranzilla, which is the baddest of the bad. I don't know if that's the guy you talked to or not, but he does build some awesome stuff. I think to figure out what you need you need to tell us a little more about what your doing.
If your gonna drive this thing alot on the street - I'd say consider the T-56 Magnum, or getting a divorced bellhousing TR6060 (I'll look up what shop it was that was doing that).
If the car will be seeing street/strip duty, I'd say get a built T-56 or T-56 magnum
If the car will be seeing sub 10 sec passes at the track - maybe you wanna consider a face plated T-56, it won't shift smooth on the street or sound too pretty, but it's almost unbreakable.
Like I said, it depends on what you wanna do.
Old 03-04-2012, 10:27 PM
I will call all 3 shops tomorrow and get some info. I hope to place an order by the end of the week. Thanks for the info on the gear ratio's. I'll inquire about that as well.
Old 03-13-2012, 03:35 PM
orangevert's Avatar
orangevert orangevert is offline
Originally Posted by 69/RS View Post
I plan to drop in a Blown 427 in my 69 Camaro and looking for a TR6060 to handle at least 950RWHP. Anyone know where I can find a new(Not rebuilt) TR6060 tranny....at a fair price? Thanks in advance
There is a rebuilt one on Denver Craigslist right now, 719-339-2823 I talked to the guy last night and he still has it.
Kirk
Kirk
67 Convertible LS7 BBC 542HP.540 TQ
400 Turbo, 12 bolt posi, 13"12'' CPP Disc, Hotchkis connectors, belly pan.. Hush matt. 3" mandrel bent and load of other stuff.. More a show an Go..
Old 03-13-2012, 04:45 PM
Thanks Kirk,
I found the AD but doesn't say anything about being rebuilt.
I contacted Rockland Standard Gear and looks like I will be following up with these guys. They said 1 to 3 days build time + shipping. I can run a card over the phone.
