Old 03-13-2012, 07:22 PM
67RS/SSx2 67RS/SSx2 is offline
Gotta love an LS engine in a 69 Camaro!
Old 03-14-2012, 05:24 AM
GRob GRob is offline
Payton, why are you selling your car? Saw it on eBay. A shame.
Old 03-14-2012, 06:13 AM
Payton King's Avatar
Default Yep
going to build a track car.
Old 03-14-2012, 08:22 AM
Rybar's Avatar
Rybar Rybar is offline
Originally Posted by classiccamaro View Post
By the way..... RYBAR, your car rocks!! I followed the thread on your upgrade with the rims/tires. I just love the stance, color, etc.... Given that you have the LS1.....would you say that your car has a ton of power, punch, or problem breaking those BIG rear tires loose I'm a big block guy, so I have really come to love the torque aspect of a street motor, if you know what I mean?
Well a stock cube 346 cannot match the torque of a BBC. But top end HP on 5.7-6.2 LSX can equal milder BBC's. If you want torque then I would really go for the largest cube motor, maybe a cam with a broader torque range. My setup lacks low end but can easily spin the 335's at will. It's a little more peaky but on the upper RPM it's moves pretty good.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 03-14-2012, 10:25 AM
NOPANTS68 NOPANTS68 is offline
Like Rybar said- the BBC torque won't be there unless you add some cubes to the equation, but keep in mind that you will be touting around 200 less lbs as well. All of it comes right off the nose of the car too.
FWIW- I ran 325/50/15 MT drag radials @ 18 PSI and could fry them at will with my little 346 and a T56.
1929 Roadster Pickup
1961 Chevy Parkwood Wagon
1956 Chevy 210
Smithcraft Collision and Restoration
Newcastle , CA
Old 03-29-2012, 09:06 PM
JMitch19's Avatar
JMitch19 JMitch19 is offline
Originally Posted by Rybar View Post
I just looked up the 799 Heads, they seem like a decent stock head. I'd deck them to gain compression and seems with a mild cam you should be around 430 rwhp according to LS1tech. That's pretty good power.
The 799 is the same as the 243(01-04 Z06) head minus the light weight valves. For the money they are really hard to beat.
If your thinking about having any work done to the heads do yourself a favor and look at http://www.advancedinduction.com/LSX...43GMPRHead.php If you spend much time on ls1tech.com you will see lots of people raving about their head program.
Jason Mitchell
1971 Camaro 416 LT1 Project
