Old 05-12-2012, 12:57 PM
Lateral-g Moderator
I've ridden in all their test cars and a few of my own, they all have some gear wine. Its pretty standard I think.
Old 05-12-2012, 02:36 PM
FETorino's Avatar
FETorino FETorino is offline
Originally Posted by coolwelder62 View Post
Did you follow the break in process right.After install It must be driving 20-30 miles (vering speed's but not thrashing on it) then allowed to fully cool. Then repeat the process.If the break in process is not followed to the letter it will make noise.This is not DSE's or Moser's problem.DSE is very easy to work with.They do thing's right and ask that their customer's do the same.
yeah, tru tracs can get pretty noisy, but what noise are you experiencing and what fluid are you using?
which one applies to your situation
Howling- accelerating, deceleration, up hill, down hill coast
Whine
Knocking- heavy, moderate, and light (clicking)
Rubbing noise-turning left or right
Like he said 1. Did you break it in correctly? If not then you may be the cause of the problem.
Additionally
2. What gear oil are you running?
3. Who did you buy the third member from?
Different gear sets are different. Some are consistently noisier. The ratios and the carrier play a role in the amount of noise. Did your conversations with the builder say your goal was performance and durability or quiet comfort?
Bottom line is some noise is an acceptable consequence of a performance rear. You aren't describing the noise and when it is occurring so who knows if this is what you have or if it is improper break in or if it is a mistake on the builders part.
Rob in SoCal
Old 05-12-2012, 04:08 PM
coolwelder62's Avatar
Every 9 inch ford gear set I have ever used whined.Even after correct break in.I have many differant brand's.And they all have forum of nosie.I think that is par for the course.
Old 05-12-2012, 04:26 PM
chr2002ca's Avatar
You could try wrapping the carrier in several layers of Dynamat. It worked great on the whining noise my first wife made.
Chris Robinson
Old 05-12-2012, 04:32 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
Originally Posted by Jamess113 View Post
I think he means it was bought new and he has put 200 miles on it.
Ooohhhhhhhhh...okay!!!!!!!!
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 05-12-2012, 04:54 PM
pokey64's Avatar
pokey64 pokey64 is offline
Well if that don't muffle it then I'd just run open headers to drown it out!
//Ed
//1964 Impala SS
//1966 Chevelle (Family Hauler)
//1969 Camaro (Hers...)
Old 05-12-2012, 05:09 PM
Ron in SoCal's Avatar
You really need to work on your personality Chris...
Ron in SoCal
69 Camaro in progress
Old 05-12-2012, 05:28 PM
FETorino's Avatar
Originally Posted by hulsund View Post
I bought the third member from detroit speed brand new and do the break in after instruction from them. I use non syntetic gear oil from texaco 80-90w
What is the noise?
Does it howl?
Does it whine?
Does it knock or click or clunk?
Does it do it under acceleration or deceleration or cruise?
Rob in SoCal
Old 05-12-2012, 05:48 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Do I need to help you hide a body?
Curtis
Old 05-12-2012, 05:55 PM
chr2002ca's Avatar
Same thing my 1st grade teacher said. Old news.
Chris Robinson
