Old 08-11-2012, 10:41 PM
Sieg's Avatar
Sieg Sieg is offline
Default SBC Gen 1 headers
I may need a set of headers in the near future. From my research it appears Dynatech's are the best fit, quality, and value for ceramic coated headers.
Should I be considering others?
Is the collector with ball & socket flange desirable?
My car has a 350, stock subframe, Saginaw fat steering box, manual, no a/c, AFR heads, 2.5" exhaust.
Existing header is relieved at the steering box to gain 1/16" of clearance which works due to solid motor mounts.
Thanks!
Old 08-12-2012, 05:44 AM
Track Junky's Avatar
I like the Hooker Super Comp's. With your set up you could probably get away with 1 5/8" primaries but I would get the 1 3/4".
Gaetano Cosentino
Old 08-12-2012, 08:33 AM
sik68's Avatar
sik68 sik68 is offline
Dougs D368 headers fit my car really well, clearing the pitman arm and power steering box and werent too expensive. That's the 1-3/4 part number...the 1-5/8 header may fit even better.
Steven
1968 Camaro: "TRACKDAY"
Build In Progress: https://lateral-g.net/forums/showthread.php4?t=10706
Old 08-12-2012, 12:13 PM
Flash68's Avatar
Flash68 Flash68 is offline
Hooker Super Comps really aren't the best fitting and they hang lower than most other headers it seems. Gaetano -- whatchu talkin bout Willis?
I know Mike P (mdprovee) just switched from Super Comps to Dynatechs on his 1st gen due to clearance issues with the Tru Turn install and he gained the needed clearance there FWIW.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 08-12-2012, 01:07 PM
If there was a smiley shruggin' his shoulder's I'd use it. What can I say, for the money I like them
Gaetano Cosentino
Old 08-12-2012, 03:42 PM
intocarss's Avatar
My Camaro has Hookers and the drivers side one hangs down in no mans land That is the only gripe i got
