Old 11-14-2012, 04:03 AM
cheezer cheezer is offline
I used aftermarket wires with 90 degree plug boots. They have a lot more room than the factory wires do.
I just ordered the MSD wires yesterday.
Once again, thanks for the input.
cheezer
Old 11-14-2012, 01:08 PM
andrew69_04 andrew69_04 is offline
I ran into that same issue with a set of SW headers on a 2006 GTO. The MSD wires will fix your problem since the boots are bendable so you can make them fit how you want. should fix your issue
69 Z28---awaiting DSE 4 link kit
79 Z28 LS2 4L65e swap--going in for paint!!
Old 11-14-2012, 03:14 PM
CarlC CarlC is offline
Had exactly the same problem. I ended up using the stock wire but used these http://www.kingsbornewires.com/produ...&categoryId=98
They fit perfectly and for $3.50 each it's a deal if you already have a set of wires.
http:www.vaporworx.com
Old 11-20-2012, 05:24 PM
gray86hatch gray86hatch is offline
Good luck with the MSD. The boots are cheap. They don't snap on the plug after removing them a couple times.
If you take the heat shield off the stock wires you can bend them just a little to clear the header.
If you are buying new wires get a custom set from FIRECORE50. They are the best wires I have ever had on my car.
Tim
86 mustang
454 lsx FTI ls3 mast 4500 9.24 144 pump gas dragradials
79 z28 29k org miles. DSE suspension Bonspeed GTB
