Old 01-08-2013, 09:44 AM
barrrf's Avatar
barrrf barrrf is offline
Originally Posted by marolf101x View Post
Ray is correct, you want your lower control arm parallel with the ground.
Let's say you have that with the current setup. . .nice thing about a "tall, drop" spindle is the lower arm stays exactly where it is, but the car is a couple of inches lower and the upper arm is now angled up so it increases camber in a turn, which aids handling. (if your lower arm is not parallel with the ground we have other things to look at).
The reason we state these spindles should only be used with tubular arms is that we cannot ensure there is no ball joint bind with the OE arm (if you install our entire "kit" we know where everything is). I would try them out, but make sure you don't reach ball joint bind as this is a major issue.
If you have bind you can pick up the upper control arms as well, which will resolve the problem (as we change the ball joint angles). It will take a little more out of your wallet at the moment, but you'll be closer to that coil over setup you really want anyway.
True - and thank you!
'69 Chevelle Malibu LSX370, 4L80E, Brembos, hydroboost, 12 bolt, c/os, etc.
You can call me Bart
Old 01-16-2013, 06:02 AM
barrrf's Avatar
Is there any reason to NOT to go with tall spindles and stick with the factory height jobs?
Old 01-16-2013, 06:46 PM
Supporting Vendor
If the tall spindle creates ball joint bind (this can be mitigated with bumpstops).
If you don't want increased camber gain.
If you are using tall ball joints (again, will create ball joint bind).
Skunk Werks
Ridetech
www.ridetech.com
Old 01-19-2013, 02:10 PM
71 RAT's Avatar
71 RAT 71 RAT is offline
Originally Posted by black67malibu View Post
I've been speaking with the guys from SC&C about my 67 chevelle. I was talking with a guy named Marcus and he gave me some great info for my car. Might be worth a phone call.
2nd for SC&C I've been running their stage kit for several years now. One of the best mods I've done to my Chevelle. My opinion.
71 SS 454 TH400 2.74 1st gear GV Overdrive 3.55 Gear SC&C Stage 11 QA1's 4 Wheel Baer Brakes AGR Box Straub SR .630 .612 lift 240 256 [email protected]
83 K20 454 TH475 NP 205 Dana 60 Track Lok Detroit Locker Rear
58 Ford 821 Powermaster Loader Backhoe Restored Family Heirloom
Old 02-08-2013, 02:12 PM
MCB Matt's Avatar
MCB Matt MCB Matt is offline
Stock height tall spindles and coilovers.....Easy and adjustable....Ridetech would be a good choice in your case!
MCB
MCB Parts - Matt's Classic Bowties
5360 Gateway Plaza Dr.
Benicia, Ca. 94510
866-628-8746
TEXT ONLY: 925-989-9091 (Replied 8-4)
www.mcbparts.com
Email: [email protected]
Like us on Facebook for exclusive offers, info and chat: www.facebook.com/mcbparts
Hours: Monday to Friday 8am - 4pm Pacific
We ALWAYS enjoy talking to our customers!
We have a full time staff to answer ALL Questions, Tech Support or Order Status Tracking!
Old 02-09-2013, 09:22 AM
exwestracer's Avatar
exwestracer exwestracer is offline
Didn't see what size wheel you are planning on running, but keep in mind that drop spindles can have clearance issues on smaller diameter wheels. Also, a larger wheel with ultra low profile tires won't need as much camber gain as a smaller wheel with more sidewall height. This might factor into your decision on spindle height.
That's one of the main reasons I recommend starting with the lower arm (effectively) level. It eliminates one of the major variables in optimizing the suspension for the tire used.
Ray Kaufman-Wyotech chassis fab instructor
Custom suspension design and consultation.
(Now 2) Big Block asphalt supermodified ('cause too much is never enough...)
Old 02-09-2013, 01:54 PM
barrrf's Avatar
19x8 with 245/35 & 20x10 with 305/35
I think anyways.
