Old 10-09-2013, 10:56 AM
Code510's Avatar
Code510 Code510 is offline
The other option is the Dakota Digital set up. They have a harness that plugs directly into the computer that hooks to the gauges.
http://www.dakotadigital.com/index.c...rod/prd722.htm
Then use this module to connect to the engine computer:
http://www.dakotadigital.com/index.c...rod/prd752.htm
Obviously this method doesn't use the plug that you are picturing, but sort of accomplishes what you're trying to do as well.
Just another option for yah!
www.code510.com
Old 10-09-2013, 11:16 AM
hulsund hulsund is offline
Default Camaro 69 dash
Thanks for information code will check
Old 04-02-2014, 12:33 AM
Hello is that no firm as has build/produced dash to directly conected to that buikhead conector
Old 04-09-2014, 11:12 AM
Jim98ta's Avatar
Jim98ta Jim98ta is offline
Not quite sure if this is what you are asking or not.
If that is the GM engine controller for LS engines, that bulkhead does not have the wires in it for what you are asking. It has the check engine, tach wire, and some others in it, but it does not have turn signals, fuel sender, etc. in it.
You will be able to use some of them for whatever instrument cluster you use, but the bulkhead connecter in the gm controller isn't really an instrument cluster connection.
69 Camaro RS - Alston G-Link, Speetech front control arms, LS2/LS3 engine, Vortech T-trim, Magnum T-56, Iforged Monaco wheels.
www.fquick.com/jim98ta
Old 04-09-2014, 02:45 PM
bille bille is offline
is this what you are looking for?
http://www.speedhut.com/gauges/36:5/freedom-gauges
Bille
