Old 10-07-2013, 12:15 PM
hulsund hulsund is offline
Default New dash camaro 69 lsa engine
Hello is there someone who have build dash to conected directly to engine bulkhead to an camaro 69 with LSA crate engine . See photo
Old 10-08-2013, 12:21 PM
Default Picture
Her is more photos of the bulkhead
Old 10-08-2013, 12:57 PM
Bsinclair Bsinclair is offline
i have read your question multiple times yet i still don't understand what your asking? can you be more specific as i think there are members that can point you in the right direction..
Old 10-08-2013, 01:00 PM
Hello is it possible to conect an aftermarket dash directly to this bulkhead conector
Old 10-08-2013, 09:52 PM
Vince@Meanstreets's Avatar
yes, you have to get the right pin connectors. http://www.eficonnection.com/eficonn...torSearch.aspx
What do you plan on hooking up to the harness? Complete gauge set, lights, turn signal indicators? Or just speedo, tach and fuel?
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 10-09-2013, 12:17 AM
Default 69 dash
Hello want to buy an complet dash with all gauge and all harness i need . So think to use the bulk head conector for all engine data ,if that is possible.
Old 10-09-2013, 12:56 AM
You are going to have to find a shop make it for you. Or make it yourself.
Its going to be a large connector.
Do you have a instrument panel for it now?
Dealer for
NEVER FORGET -11
Old 10-09-2013, 01:28 AM
Default 69 camaro dash
Hello i dont have an instrument panel yet . Hope to find an panel that was plug and play if you understand.
Old 10-09-2013, 09:32 AM
i would contact Speertech or John Leonard at modern vintage. they both build harnesses and could probably help with your project. are you wanting to use stock gm gauges or aftermarket? if using a Dakota digital gauge set up you can use a bim module to get the data.
http://www.speartech.com/
http://modernvintagesystems.blogspot.com/
http://www.dakotadigital.com/index.c...rod/prd752.htm
Old 10-09-2013, 10:12 AM
Default Camaro 69 dash
Will send speaertech an question about this . Thank you
