Old 01-06-2014, 04:58 PM
Ron in SoCal's Avatar
Originally Posted by st83 View Post
Haha there's a very good possibility it is, but I'm going to have to claim ignorance on that! The gf gets the house, and I ask no questions, and I get the garage and she asks none... It's a good compromise in my opinion lol!
We have the same rule except I add the TV room as my domain. A man's gotta watch sports in comfort. No girlie stuff
Now if I had a TV room in the garage I might sleep out there
Ron in SoCal
69 Camaro in progress
Old 01-06-2014, 05:38 PM
6D9 Matt's Avatar
6D9 Matt 6D9 Matt is offline
Thats the goal in my next house. LOL
'69 Camaro
416ci / T56 / 9"
Turbo in the works...
Old 01-06-2014, 06:24 PM
st83 st83 is offline
I just trained her to only speak during commercials, understand that anything told to me during a sporting event (especially football, or hockey!) will be promptly forgotten, and why "snuggling" and sports don't go together.... so for now I'm putting up with the girlie stuff till I get my own room lol!
Old 01-06-2014, 07:08 PM
I guess, as long as you have the remote and a DVR...
Ron in SoCal
Old 01-10-2014, 05:45 AM
Ron Fox's Avatar
Ron Fox Ron Fox is offline
Originally Posted by will69camaro View Post
245/35/19 = 25.75"OD (3.4" sidewall)
335/30/20 = 27.9"OD (4" sidewall)
345/25/20 = 26.8"OD (3.4" sidewall
As you can see above if you base it on your front tire size you have 3.4" sidewall and approx 25.75" overall height. With the 1" diameter larger rear tire you want to carry at a MINIMUM the same sidewall (relating to 1" taller rear tire).
The 345/25/20 matches the front tire perfectly!
However it depends on the look you want to go for. An approx 28" rear tire is pretty sall, so will give the car the "stuffed" look. It's over an inch taller than the other rear tire option and 2 inches taller than the front! Again depends on the look you're going for.
If it were me, I'd go the 345/25/20. You get the additional width (just less than 1/2" wider) which is always a good thing and it matches the front perfectly.
I'm going with 18/19 combo on mine, but for reference you can see us test fitting a 345/25/20 on my car so you can get an idea of the aspect ratio (sidewall).
Good luck!
I am having the same problem on what combo to use. I want the taller tire and I want the space on the right and left side of the tire filled up. I want the suffed look but I want it to look somewhat equal to the front in regards to tire size and look.
Do you have any photos of the car above setting on the ground? While on the ground did the wheels go up further inside?
Thanks.
Ron
1969 Firebird, 4-speed Coupe
If GOD is for us, then who can be against us!
Old 01-10-2014, 05:47 AM
Ron Fox's Avatar
Alright, so the wheels finally arrived! My hats off to Chris Coddington and Hot Rods by Boyd! Took about a month and a half from when I ordered them till I got them and that includes a delay at the border, and the Christmas holidays! Ended up going with 6" backspacing in rear, 4.75" in front... 20x12 and 19x8 front:
Nice wheels. Do you have any photo's with the tires mounted?
Thanks.
Ron
Old 01-10-2014, 06:49 AM
Thanks.
I will try and get some more soon. My car will hopefully be out of the painter today and we're going to see about setting ride height and trying out some wheels with same tire. I will post as soon as I get more info. You guys are the first to receive the updates I post!
I want the stuffed look also so looking forward to ordering my own wheels/tires when I get it figured out fully. Hoping to get a hold of Anvil so I can get diff front inners and run 285 fronts
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 01-11-2014, 01:47 PM
[QUOTE=Ron Fox;528105]Nice wheels. Do you have any photo's with the tires mounted?
Thanks.[/QUOTE
I haven't mounted the tires yet... But as soon as I do and get them mocked into place I'll be sure to post up pictures!
Old 01-11-2014, 04:27 PM
I'm wondering... I want to go with a 255/35/19 tire in the front, but most tire manufactures recommend a 8.5 - 10 inch rim and my fronts are 8". Anybody run that tire size on an 8" rim? Will it fit, and look normal, ie no weird bulge on the sidewall or anything?
