Old 11-13-2013, 03:33 PM
Restocreations's Avatar
Restocreations Restocreations is offline
And a few more of the front end and hood fitment.
Old 11-13-2013, 03:35 PM
250 Hours
The passenger door stuck up a good bit above the body and no amount of adjustment in the hinges would help. I had to sand the top of the door down to get proper fitment. The gap was wide at the front, so i had to narrow it as well.
After testing the effectiveness of the weatherstripping at the top of the door, i decided it was not necessary for this car and smoothed the jambs.
Front half of the car and engine bay in Epoxy Primer.
Old 11-13-2013, 03:36 PM
Took delivery of the SRIII Chassis on October 3rd. Im very happy with the quality of the components and my choice to go with the satin finish instead of gloss!!!
Old 11-13-2013, 03:37 PM
Back half in SPI epoxy
306 hours total Body work is brutally time consuming!
It only took around 2 hours to remove the rear compartment and jackwell and temporarily install the new wheels wells and floor to check fitment. Mike's/SRIII rear floor really simplifies things and was well worth the 350.00. I payed 2300.00 to have the old floor cut out and a new one fabricated for my 66 last year. Total time in this floor will be around 6 hours once all is said and done. Cost is 350.00 for the floor and 40.00 for a tube of 3m panel bond.
The official point of no return!
One more thing i dont necessarily want to throw away, but dont have a use for.
Old 11-13-2013, 03:39 PM
Shot from the underside of passenger wheel well. Im going to smooth out the transition from new to old glass. No reason to cut corners at this point.
Originally Posted by wfo guy View Post
I hope you're enjoying your project. I'm enjoying watching it.
309 hours
Rear floor and wheels wells installed.
Old 11-13-2013, 03:41 PM
354 hours
I block sanded the entire body again, then applied two more coats of SPI black epoxy. After the SPI black epoxy sat overnight, i applied two coats of Evercoat Slick Sand and then sanded with 180 grit.
One of those small details that eats up time. Hinges rebuilt and coated with SPI black epoxy.
I decided to ditch the fuel injection emblems and go with the early style 63 emblem
Old 11-13-2013, 03:42 PM
434 Hours
After seeing a 63 split window without an antenna at SEMA i decided that i would copy that person's car and do the same. Removing the antenna gives the rear of the car a much sleeker look. I used a Hideaway antenna on a custom Mustang i built last year, so i will do the same for this one.
Two more coats of slick sand and a whole hell of a lot more sanding. I sure hope this thing is as smooth as glass! Oh, and surprise...I ordered SPI black today for the basecoat. I saw a 63 in cyber gray a few weeks ago and it did not look so hot. I thought about switching to silver, but most every 63 restomod i have seen in the last year has been silver, so black it is...straight black, no metallic.
Old 11-13-2013, 04:54 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
Those man hours add up rather quickly, don't they.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 11-13-2013, 05:05 PM
Ron in SoCal's Avatar
Props man! This is gonna be one bas a$$ car when done.
Ron in SoCal
69 Camaro in progress
Old 11-13-2013, 05:34 PM
Sure do! Now i see why show quality paint jobs are so expensive. Makes me think the 11 grand i paid for a paint job last year was well worth the expense.
