Old 01-28-2014, 09:29 AM
Solid LT1 Solid LT1 is offline
525HP LS3 has the ASA cam in it. Pretty big and lumpy idle cam, the GM tuning can definitely use some refinement. I tried to build an equivalent using a Comp profile but quickly found out my 0.588int/0.608exh lift wouldn't fit with the flat tops in a Vette LS3. You see all kinds of BS on the boards about big crammed LS3 motors only way a big cam will fit is if you have VVT LS or L92 truck motor with notched pistons. The ASA cam is only 0.525 lift it was designed for LS1 motor and doesn't utilize the great airflow of the LS3 rectangular port head. I ended up tearing part my 3K mile Vette dry sump LS3 and fitting a set of Mahle pistons with lighter Manley rods another $2K investment but, motor was a $4500 bargin to begin with. good side was I Craigslisted the LS3. Pistons/rods for $250. Buying a GMPP LS3 gives you the Vette flat top pistons my 228int/236exh 113LSA Comp grind had around 0.040" piston to valve clearance and no shifting of cam timing could gain anything in that department. One other thing, if you are running a factory dry sump set up I think timing chain choices are marginal at best, I'm going to work on possibly fitting a double roller chain into my motor with reworking of front cover. Everything is tight!
Old 02-07-2014, 12:20 PM
gnx7's Avatar
gnx7 gnx7 is offline
I would look for a take out LS7 and do a cam/dual spring swap and upgrade exhaust valves to s/s if they haven't been done already. 50+ cubic inches with a medium size cam will paint a big smile on your face and have 50rwtq+ over an LS3.
Probably won't cost much more than an LS3 with upgrades.
Old 02-07-2014, 01:45 PM
Firebirdsteve's Avatar
Firebirdsteve Firebirdsteve is offline
Originally Posted by mikeextrafast View Post
how is the driveability with the 525 hp engine? you auto or stick? Is the cam and valve train the only things different?
Sorry!
Just saw this...
Drivability is great! Excellent throttle response, pulls like hell!!!
Stick
L92 heads!
Does have a low RPM surge that needs do be attended to.
Cheers,
1981 Pontiac Firebird
Build by Speedtech Performance
http://www.speedtechperformance.com/...rod/prd287.htm
