Old 12-25-2013, 02:25 PM
mikeextrafast's Avatar
mikeextrafast mikeextrafast is offline
Default ls3 upgrades
Getting ready to take the ls3 plunge,However i want a little more hp. I am wanting to do a set of ported heads and a small cam ... What would be the best way to go with this? Buy a new crate engine and put the new heads on and sell the stock ones? have a complete engine built?? Any other ideas? looking for the most cost effective way
Old 12-25-2013, 02:39 PM
You may find the LS3 crate engine from GM your best bet if you haven't bought anything yet. I'm referring to the 500 something horsepower model.
If you decide on a different path, the stock LS3 heads support a good deal of power. No need to go aftermarket typically. Not sure on costs but you may also find fully ported LS3 heads well within your budget. Or simply have your stock heads ported on the exhaust side to potentially save even more money and make good gains.
Old 12-25-2013, 05:52 PM
RdHuggr68 RdHuggr68 is offline
Mast Motorsports sells a combo kit, cam and heads suppose to be a sweet setup!If you have the funds.
Old 12-25-2013, 09:29 PM
Rybar's Avatar
Rybar Rybar is offline
My buddy made 499 rwhp and 463 rwtq with a Mild cam and otherwise stock dry sump LS3 in his Grand Sport C6 corvette. I would look into the same cam he has its from Geoff at Engine Power Systems (EPS)
http://www.engpwrsys.com
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 12-26-2013, 06:03 PM
71RS/SS396's Avatar
I wouldn't spend the money on porting the LS3 heads you won't see a huge gain, I would use that money for trunnion mods to the rocker arms, better retainers, and springs.
Old 12-29-2013, 03:58 PM
The crate motor I was thinking of is this one https://sdparts.com/details/chevrole...mance/19301360
Old 12-29-2013, 09:49 PM
fishface's Avatar
fishface fishface is offline
I will be looking for.pretty much the same with good.idle and driveability. I am planning on a.stock ls3 with a Katech Torquer cam and springs and trunion upgrade. With headers and tune hoping to be between 480-500 hp.
Old 12-30-2013, 08:19 PM
yeah,,, driveability and good idle are a must
Old 12-30-2013, 08:54 PM
Firebirdsteve's Avatar
Firebirdsteve Firebirdsteve is offline
I have this....you wouldn't be disappointed!!!
1981 Pontiac Firebird
Build by Speedtech Performance
http://www.speedtechperformance.com/...rod/prd287.htm
Old 01-01-2014, 06:51 PM
how is the driveability with the 525 hp engine? you auto or stick? Is the cam and valve train the only things different?
