Old 01-24-2014, 11:08 AM
69greyghost 69greyghost is offline
Originally Posted by Solid LT1 View Post
230/236 on a 112 LSA? That's pretty big with lots of overlap. The MAF if your running one won't be to happy if it's anywhere close to the throttle body and the MAP sensor, it's not happy at all at idle Ill bet. A good tuner can work around most of this where do you live?
I live in San Leandro Northern California. If you look at my photobucket you can see how my set up is. I was going to have Rick from synergy in Fremont California. I have heard really good things about that place.
Old 01-24-2014, 11:30 AM
SSLance's Avatar
SSLance SSLance is offline
Originally Posted by 69greyghost View Post
I dont remember. It was 100% synthetic I remember that much. I will check and find out. The trans doesnt feel stiff tho.
Full synthetic fluid can cause the T56 paper blocker rings to swell and make it difficult to shift into and out of first and reverse...
Just google "T56 Synthetic fluid" and start reading.
Lance
Old 01-26-2014, 07:18 AM
Originally Posted by geberhard View Post
Anthony,
Good to hear on the progress! Quick questin is teh clutch a Ls1 or Ls7 style, and did the kit include flywheel, etc/ Have you tried contacting Luke Perf on the clutch? Also before going into the tune direction some steps you can check to make sure the system does not have any other issues.
Was the clutch a complete kit, and new, never installed? The reason I ask is because LS7 style clutches behave differently from LS1 clutches and will need to be "reset" before installing.
With the car off, with the clutch pressed are you getting decent resistance and return? With multiple presses, any changes?
With the engine on, does it change dramatically? Was the slave bled correctly, and which one did you use? Drill modded or not?
I am assuming the install, orientation of clutch disk, bleeding, etc are all good.
Good luck, Gui
Ok I think I have resolved my issue with my car, I think anyway. So I drove it yesterday just real quick, didnt get through 4th. However it drove really well and that surprised me. No issues coming out of first and it accelerated good. Then after I stopped and examined my car, I tried to take off again and had the similar issue that made me make this thread. I realized however the emergency brake was on and this time in particular thats what caused me to have issues getting rolling without the car stalling out. I am hoping that this was the issue and a dyno tune will remedy any other bugs my car may have. I know I sound like a duffus but I wanted to at least share that the car was running and shifting 10 times better.
Old 01-26-2014, 07:30 AM
glassman's Avatar
glassman glassman is offline
I had shifting issues in my swap. The input shaft wasn't shimmed properly, and i'm running the same clutch setup as you. My guy who helped me with the swap is a very good LS tech, but hes slammed and a one man band, I'm in Livermore.
Keep us posted on the results, and let me know if you have any questions.
Also, show us some pics...buildthread? Mike
Mike
Old 01-26-2014, 11:12 AM
I know mike, I really want to do a build thread but am not really sure how to make the pictures fit. I have a MacBook, also I have posted every single pic I have of my car on photobucket. There are even. Few videos of it being driven with the ls motor and when I first got my rs light conversion done on the car. I just need to know how up post to this site so I can create a build thread. My photobucket page link is in my signature. Thanks for the support mike. I hope you see me at some car shows this year at some point.
Old 01-26-2014, 03:59 PM
glassman's Avatar
Its super duper easy, postin pics that is. Just have your photobucket window open while your doing your post and following the instructions. Basically, just use the [img] icon and it self load and seems to self size....
Born and Raised in San Leandro, Manor, Floresta Gardens, the family business on Marina from '61 to '07, and family (lots) up off of Bancroft from the 60's to the 90's....still have lots of friends and connections there....
Mike
Old 01-27-2014, 11:32 AM
Thanks Mike, I am gonna try that later today. We are almost from the same area, when my car is driveable we should link up or something. How does thats sound?
Old 01-27-2014, 02:10 PM
geberhard's Avatar
geberhard geberhard is offline
Anthony great to hear. Back on Mike's note, you can also enter the "tags" manually.
Copy the address of the pic:
http://s1278.photobucket.com/user/69...5a79.jpg.html][IMG]http://i1278.photobucket.com/albums/y513/69greyghost/IMG_3253_zpsd04c5a79.jpg
and add [XXXimg] on the front of the address - minus the XXX
and then [XXX/img] at the end of the address:
[XXXimg]http://s1278.photobucket.com/user/69greyghost/media/IMG_3253_zpsd04c5a79.jpg.html][IMG]http://i1278.photobucket.com/albums/y513/69greyghost/IMG_3253_zpsd04c5a79.jpg[XXX/img]
remove the XXX on both and you will see the picture embedded:
Old 01-30-2014, 06:50 AM
I feel like a dumb ass, I cant get this right!I give up, am I supposed to put it in the attachment part?
Old 01-30-2014, 09:28 AM
geberhard's Avatar
No worries, just inline as you are posting. Look at my note above.
I.e. type your reply then copy the location of the image like http://wahteverpicture.jpg then ad the [imgxxx]http://wahteverpicture.jpg[/imgxxx]
remove the xxx on the IMG tag above
Gui
