Old 05-27-2006, 05:36 AM
quadfather quadfather is offline
i agree i almost always use a 9 gold lens, 10 when doing aluminum. i like the gold lens. it seems more the colors are more natural doesn't have that green look to the puddle.
Old 05-28-2006, 11:17 AM
Kustomchopshop Kustomchopshop is offline
its very easy to see depth in the weld puddle with the gold lense, you can see impurities and comtamination on the puddle if you look closely and compensate for what you see.
Matt Inscho
Kustom Chop Shop
Decatur, AL
256-227-5670
Old 05-28-2006, 01:32 PM
Matt@Lateral Dynamics Matt@Lateral Dynamics is offline
Just one thing to keep in mind boys...everybody's eyes are different, and everybody will see best with different filters. You really shouldn't be telling somebody that a gold 10 is the best. It might be the best for you, but that's all you know for sure. I can't stand the gold filters.
Case in point, I use a black 10 on up to 280 amps dual shield. Most people would be using a 12 atleast, and some a 14 with sunglasses on under their hood. Seen it.
Old 05-30-2006, 03:48 PM
rwhite692's Avatar
Scott here is what I do when I'm having trouble seeing well (I'm using an auto-darkening helmet and I'm sure settings vary a bit from helmet to helmet)
I use a setting of about 11 when I'm mig welding. But what I do is to set up a big halogen work light so that the area I'm welding is extremely brightly lit. That way, when the helmet is "undarkened" I can see VERY well for positioning, etc.
Then, Even though the helmet is darkened while welding, the high degree of light from the halogen does get some of this "ambient" light through and your visibility of the surrounding area improves quite a lot in general...Of course just make sure the Halogen light isn't coming from behind you so that you dont get glare/light inside the helmet...
Project update thread here:
My Lateral-G Page
My Shop Build:
Old 05-30-2006, 03:59 PM
Originally Posted by rwhite692
<snip>Then, Even though the helmet is darkened while welding, the high degree of light from the halogen does get some of this "ambient" light through and your visibility of the surrounding area improves quite a lot in general...Of course just make sure the Halogen light isn't coming from behind you so that you dont get glare/light inside the helmet...
I've never understood this concept. Seems to me that the arc is the biggest flashlight you'll ever get your hands on... Are you really getting that much help from the added light you're using?
I've never tried it, and don't have the need to, so I'm not doubting you. I just don't see how the halogen could provide more light than an arc bright enough to really ruin your evening.
Old 05-30-2006, 04:15 PM
rwhite692's Avatar
Matt, I don't have an explanation for you... As others have noted what works for some people might not work a whit for others...I have just been welding for a lot of years and have found some things that help me.... Scott asked for help seeing what he is doing when welding thin guage material, and so I told him what works for me...When I am welding, it sometimes helps to be able to see faintly lit reflections off various parts of the work in the field of view in order to establish reference points and know where I'm at as I go...Just my $.02. - Rob
My Lateral-G Page
My Shop Build:
Old 05-30-2006, 11:49 PM
69camarofast 69camarofast is offline
Cool
I try to keep a 11 shade on my welding projects..and for tig i change to a 12 both lens's i like to use gold..because of the reflection... ..
Old 05-31-2006, 06:18 PM
EFI's Avatar
EFI EFI is offline
For a years I used a standard hood with a #9-10 gold lens. Now I use a Optrel Satellite A/D helmet. It has a shade range selection & shade level control. Shade settings range from 5-9 or 9-13. Optrel doesn't offer the cool graphics several other helmet manufactures offer, but if you spend lots of time staring at weld puddle and want a great performing A/D helmet, this is the best I've used.
Old 05-31-2006, 09:18 PM
awr68's Avatar
awr68 awr68 is offline
I'm with Rob, I also find that a little extra light helps me see what I'm doing...especialy if I'm in or under the car and the shop lights aren't doing their job....not sure why it works, it just seems to!
Tony
'68 Camaro
Old 05-31-2006, 09:28 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Lots of good info in this thread, thanks for the replies, guys. I have to hit the welding shop tomorrow so I'll check out what they have to look over.
My LS7 69 Camaro
