Old 10-27-2014, 08:22 AM
Originally Posted by DBasher View Post
Vince where are you buying the housing ends? Moser, Currie? I picked up another housing that needs to be cut down and I need to research what ends to get for the brake set up I now have.
Dan
Go down to Fife... and talk with the boys at Art Morrison. They stock/sell Wilwood... and rear ends - and have all the jigs etc.
Old 10-27-2014, 12:22 PM
Vince@Meanstreets's Avatar
Dan
Chevy bolt pattern ends. Flush mount so you can use your parking brake bracket as a retainer.
http://www.moserengineering.com/smal...lip-axles.html
http://www.summitracing.com/parts/msr-7900fm/overview/
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 10-27-2014, 06:00 PM
Cread01 Cread01 is offline
I like the idea but the only thing I am thinking is you would have to make sure it would work with your rear end setup. it looks like it's aluminum where my rear end brackets are welded on and that could be a pain.
Old 10-27-2014, 06:08 PM
they feature mild steel plates that bolt to the housing then you weld your brackets to them.
Dealer for
NEVER FORGET -11
Old 10-27-2014, 10:43 PM
Sparks67's Avatar
Sparks67 Sparks67 is offline
Originally Posted by badazz81z28 View Post
Rick, I'm uneducated but I don't see why this would any different than an aluminum engine block or aluminum transmission case. Yeah, I guess not quite as strong as steel, but I don't see why it would be a problem. I think I saw this same rear on Ebay. I don't recall it being too expensive.
The rear end above doesn't have any specs in the photo. Here is the company. http://speedmaster79.com/tds/third-member/ perhaps someone in the thread knows this company. I suspect the casting is made overseas.
Jeff
Old 10-28-2014, 03:52 AM
Rick D's Avatar
Rick D Rick D is offline
Jeff
^^^^ Yes Jeff, I believe you are correct, but Australia? Well at least that's where the parent company is from according to their web site.
Also another interesting their US company is ProComp who sells ALOT of cheap knock off parts on flebay! You name it and they sell it, I believe they are the ones selling the fake Persision EFI manifolds?? Not sure on that one but I think I saw the ProComp name on them before.
Also on their web site the housing is $400 and axle tubes are $80 so a few bucks less then flebay.
Rick
Old 10-28-2014, 10:24 AM
Gambit's Avatar
Gambit Gambit is offline
If that's procomp in Australia be very wary. They don't have a good reputation here. Never personally used their items & can't say I would. I'd rather spend a bit extra upfront than replacing new parts
69 Camaro, LS1, T56, HTV2300, Brembos, Forgeline
As close to finished as it’ll ever be..
Old 10-28-2014, 11:10 AM
that would explain the low cost....looks cast.
Tell me though, what would one pay for a billet aluminum one made in the US??
Dealer for
NEVER FORGET -11
Old 10-28-2014, 11:11 AM
Jeff
Like everything else these days....quality control should be the concern, not the PoO
