Old 11-30-2014, 05:40 PM
David Pozzi's Avatar
Mark Stielow was asked why he hasn't done an IRS car and voiced his concerns about breakage. https://lateral-g.net/forums/show...irs#post423469 A year ago I was very interested in doing a Corvette transaxle. I was a bit concerned about the serviceability of the C6 system, the amount of work to convert the Torque tube and install it in an early Camaro, also to change a clutch, you have to drop out the whole rear suspension with torque tube. Not something you could do trackside. Once I saw the Art Morrison system I figured it was the next best thing, plus every component is 2x stronger, plus easier to do a Clutch change, easier to install. The C6 IRS is still a great idea I think, with bit better rear weight bias.
http://www.PozziRacing.com
Old 11-30-2014, 06:07 PM
mach1stang's Avatar
mach1stang mach1stang is offline
I have heard horror stories about C6 clutch swaps! But I'm thinking it could be possible to build it with the transaxle but not use the torque tube to be able drop the driveshaft and be able to service the clutch as you normally would.
Kody Willis
1969 mustang fastback - Lots of secret surprises to keep under wraps.
2012 boss 302 - BMR lower control arms, relocation brackets and pan hard bar, cortex racing coilovers, enkei 18x10.5's front and rear with 315/30/18's, offroad x pipe, lethal performance over axel pipes, SLP loudmouths.
"Your boss's exhaust when you floor it sounds like Jesus stepped on a lego in the middle of the night while going to the bathroom!"
