Old 01-03-2015, 09:07 AM
Carbo Carbo is offline
Originally Posted by Blake Foster View Post
http://www.speedtechperformance.com/...rod/prd383.htm
Here it is. an LS swap kit SPECIFICALLY designed for the TRU TURN.
Not sure what more you would want???
unless it is the T56 install kit?
http://www.speedtechperformance.com/...rod/prd386.htm
that should EASILY answer the OP question I would think.
Blake, does this kit (particularly the engine mounts) put the LS engine in the stock location where the SBC originally was positioned?
Old 01-03-2015, 10:08 AM
Rod P's Avatar
Rod P Rod P is offline
great looking install kit!!!!!I will try this one on the new build
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 01-03-2015, 11:48 AM
simbad's68 simbad's68 is offline
Default LS Swap Kit
Blake,
I'm installing a LS3 w/ F body belt drive system. With notching the frame on a first gen F body, will the compressor have clearance issue. My understanding is the True Turn swap kit uses a different frame stand.
Old 01-03-2015, 12:30 PM
Blake Foster's Avatar
Originally Posted by simbad's68 View Post
Blake,
Yes it should work. if it doesn't get a bigger grinder!
Blake Foster
Old 01-04-2015, 08:30 AM
Stovebolter's Avatar
Stovebolter Stovebolter is offline
Thanks Blake. That system does look great. Unfortunately for me, at this time I'm wanting the interior to be somewhat stock in appearance. Doesnt look like the floor pan add-on would allow the use of a stock center console? I'm actually considering not even using a console, but want to use the factory carpet. Se la vie.
I pulled the trigger on a set of long tube stainless headers 2276-7 with Hooker, Holley 12618 new gen (latest design) mounts, and the 302-2 Holley pan. Already using their X member for my TH400 which also works for the T56 I picked up from a fella in Indy yesterday. The headers will need the mod, and possibly the pan. It appears there are some people doing this set up without having to mod the pan by using 5.8" idler and pitman arm. We'll see what happens. I have a TIG so I may have to do my first aluminum mod with it. Lol. I'll update this when I get this swap started. Probably this spring. I'm collecting parts now.
Let's keep this thread going. I see this benefiting members in the future.
468 BBC, TH400, Moser 9" floater, True Forged Competitions 18x9.5 18x12, Kore 3 C6 ZO6 calipers 14" & 13" rotors, Ride Tech True Turn, Ride Tech Air TQ's, Torque Arm with Watts link, Moser CT Full Floater 9" with locker.
Old 01-04-2015, 09:10 AM
130fe 130fe is offline
Thumbs up
stock subframe-
LS3
street and performance mounts
autokraft oil pan
Stainless Works headers
ATS (Speedtech) T56 crossmember
Great clearance all around.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 01-04-2015, 09:12 AM
Originally Posted by 130fe View Post
stock subframe-
LS3
autokraft oil pan
Hey Chris,
Did your mounts place the engine in the stock location as the SBC? I'm trying to accomplish what John did to Steve's car by reusing the TKO.
Old 01-04-2015, 11:40 AM
yes the trans cover WILL work with the 69 factory console if you are wanting to use the gauges you will need to modify the mount to lift it up a bit. guess you need to decide what is more important engine/trans fit and alignment or the stock appearing interior???
Blake Foster
Old 01-05-2015, 06:23 AM
Both are important. And yes I can have my cake and eat it too. I've seen plenty of people say their car drives great and they run nothing but a stick in the floor. They've maintained the 3 degrees down and a stock interior. That's easy to find. What's hard is finding a system that works with the Ridetech Tru Turn system. Your system must sit high in the frame?
It's my understanding that Holley/Hooker did have drivetrain alignment issues early on with their one fits all mounts, but have since corrected the issue with the second generation of parts for this swap. Please correct me if someone knows otherwise?
Old 01-05-2015, 01:19 PM
It does not sit any higher than any other LS it is moved back slightly so the inner tie rod ends clear the pan, the other key is the pan shape.
we have found that yes you can runt the t56 with the stock floor, that is how the original ATS T56 cross member is, (which we still sell) but have also found that when the car gets really low the driveshaft runs uphill to the rear end which makes for some undesirable combined angles. by lifting up the tail shaft you can eliminate that situation as well it raises the header collectors to increase the ground clearance so there is more than one benifet to the system.
Blake Foster
