Old 02-11-2015, 11:31 PM
rpm56's Avatar
rpm56 rpm56 is offline
Default Bob from Bako
Hey guys and gals, I'm Bob from Bakersfield, Ca. I found your site a couple of months ago and decided I've lurked long enough, even though this seems like GM heavy site and I'm a Ford fan.
In March of 1989 I decided I needed to buy 69 Mach 1, so a buddy and I drove around town looking for one. After about a half an hour we spotted one sitting in an apartment complex. I contacted the owner and bought it for $2,500. I was in heaven driving it away. It had some rust on the rear lower quarter panels, so I drive it to the body shop for body work and coat of Porsche India Red paint.
The mechanical and suspension was your average worn out variety. One day while warning up the car on the site of the house behind a fence, I decide to top off the fluid and added some tranny fluid. Unbeknownst to me the trans was in reverse not park, so when enough fluid was added the car took off, with the electric choke working just fine. The rear body panel and right quarter were damaged from a water spigot, concrete mixer and an 8x8 wood fence post.
This rebuild I decided to strip it to bare metal and do it right. Sounded like a good idea at the time.
While the car was at the body shop I rebuilt the motor. It's a 69 351w block, bored .030, Scat crank stroked to 393, 10.2cr KB hyper floater pistons, polished and peened rods, Cloyes double roller timing chain, Comp Cams XE 268 cam for a daily driver, Melling HV oil pump, AFR 185 heads, Crane roller rockers, Weiand Stealth port matched intake, Speed Demon 750 carb, Hedman Hedders, ARP fasteners, Weiand alum water pump, Milodon 7 qt oil pan.
Once again it was painted Porsche India Red, then life got in the way.
A divorce in 1999 was followed by building an attached 975 sq ft shop to work on the Mustang.
I remarried in 2004, built a big house with an attached shop, to work on the Mustang. In 2009 I divorced and moved back to my original house, the one with the shop to work on the Mustang, which remained at the body shop. I carried on a self induced liquor aided pity party until 2011 when I quit drinking.
I brought the car home and made a long list of mods I wanted to do to the Mustang:
Fabricate tubular control arms for QA1 coilover shocks,
The 9 inch is an N case, Daytona pinion support, 3.50:1 traction lok 31 splines,
Bob
Build Thread- http://1969stang.com/forum/index.php...bitch-is-back/
There are 2 kinds of people, those who own pickups and those who borrow them.
