Little update: I've been working on a gauge panel to replace the plastic factory gauges.
I'm not too content with the way my gauge panel is at this point. I've done everything I could to salvage the stock bezel so far, but the holes are all breaking out and the thing is shaky.
I've decided to put a set of aftermarket gauges in the car. I don't want to put the gauges on a flat plate, I want to make them look like they may have been stock - I really like the way the stock gauges are in a tunnel.
So - I've decided to fabricate my own panel from steel. I'd like to make tunnels to countersink the gauges, mount the vents and switches in the stock locations - as if they were meant to be.
It's going to be something to get things looking correct. I'm sure I'll have to bodywork and paint the thing, but I might as well start sometime. If any of you have noticed, the small gauge holes in the stock bezel are egg shaped and not just circles cut out (to accomplish the angle the gauge faces) - this should be a real treat, lol.
Not too sure I want the lighter, and have no idea what the light panel above that is. Not too fond of the light switch knob either. But I think the bezel needs that raised edge to look right.
Any examples of some higher end work? I don't want it to end up looking like a sheetmetal drag car panel.
