Old 02-15-2015, 04:36 PM
FlameBroiled's Avatar
FlameBroiled FlameBroiled is offline
Sounds like your tube is being pushed back through the holder, Tighten the screws and or clamp it in a vice.
www.Eyekandykustoms.com
Old 02-15-2015, 06:06 PM
vstol vstol is offline
thanks
Old 02-16-2015, 04:28 AM
I borrowed the flaring kit and it looks like it has some miles on it. This morning I did a quick flare using the vise and it was pretty darn good. Thanks for your advise I plan to buy another one today.
Old 02-16-2015, 01:07 PM
New flaring kit and the double flares look good, thanks for your help
Old 02-16-2015, 05:58 PM
Vega$69's Avatar
Vega$69 Vega$69 is offline
After you cut the tube file it perfectly square and debur before you use the flaring tool. Also put a little lube on the tube or die end such as WD40
Old 02-17-2015, 04:41 AM
complete thanks
Old 02-17-2015, 03:46 PM
gray86hatch gray86hatch is offline
I found the tools with the wing nuts just don't do a good job at holding the tubing.
Mine you use a wrench to tighten. I have not had issues with this one slipping.
Tim
86 mustang
454 lsx FTI ls3 mast 4500 9.24 144 pump gas dragradials
79 z28 29k org miles. DSE suspension Bonspeed GTB
Old 04-05-2015, 07:06 AM
After screwing with the cheap flair tools on stainless lines I am ordering this.
86 mustang
Old 04-05-2015, 08:24 PM
Chevy Kid Chevy Kid is offline
^^^^^ This.... Best flaring tool ever. The 37* kit for AN lines works great too!
Tim
Old 04-05-2015, 10:18 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
Default flaring tool
I borrowed this kit from a buddy when I did my brake and fuel lines. This was so easy with this kit and the copper nickel lines. I was also able to do the GM quick disconnects for the fuel filter fitting. It was the 71475 kit.
http://www.mastercool.com/pages/flaring_tools.html
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
