Old 03-31-2015, 06:19 AM
barrrf's Avatar
barrrf barrrf is offline
To eliminate pad knock back caused by axle shift in c-clip style axles when running fixed calipers? At least, this is what Ive read.
Would be nice if it worked for others working on a budget that want a nice braking system that isnt floating caliper style.
Also, Why does strange say their eliminators are for use with drum brakes only? What is the issue?
'69 Chevelle Malibu LSX370, 4L80E, Brembos, hydroboost, 12 bolt, c/os, etc.
You can call me Bart
Old 03-31-2015, 09:09 PM
SlowProgress's Avatar
I know you are just kidding a little (maybe). I put mine in years ago because I drag raced a little and didn't want to lose an axle. I had stock axles due to poor funding. I worked as a mechanic for a few years and I just think the Ford style bearing is better. I saw a lot of worn axles from the GM roller bearing riding on them. When I put my big brakes on I figured the stock 12-bolt bearings could be improved with the Ford (or other) replacement. I really enjoyed working with the Torino ends and it seemed to make a good setup. I haven't seen any posts to confirm it but it seems the GM style roller bearing would also lead to more brake knock-back because the axles have a little more end play. Those are my simple reasons.
Old 04-01-2015, 07:02 AM
barrrf's Avatar
Which part am I kidding about?
Old 04-03-2015, 07:23 AM
Oh that does read funny. I was responding to Sieg ! We must have posted up at exactly the same time.
Remind me why you need to eliminate the C-Clip axles?
I agree with you on the knock back. I am not sure about Strange but the Mark Williams kit I bought years ago used a ball bearing that was only good for straight line driving. If it is something like that then maybe it won't keep the rotor positioned right for disk brakes - but I am just guessing.
Old 04-04-2015, 07:36 AM
barrrf's Avatar
Ah I see. I should probably just pony up and get the new axle. But I'll try a few wrong things first and THEN I'll do that.
