Old 04-01-2015, 02:44 AM
72Z/28's Avatar
72Z/28 72Z/28 is offline
If I'm not mistaken, when you order the rear kit and specify offset, the only difference is the thickness of that spacer.
If you have a hand held belt sander, vice, some leather gloves, and a little talent, you could 'mill' them down.
Thanks a lot Sieg. I will take some measurements for the floating caliper braket spacer and the previous fixed caliper braket spacer. Hopefully the ones came with my previous kit are thiner so I can use them on the floating caliper kit
Otherwise I have to machine the spacer
72 Camaro RS:SOLD
68 Camaro:
LS6 Engine,Tremec TKO 600,5 Speed
Complete Speedtech Subframe Kit,Speedtech Torque Arm, 9" Rearend from Strange, Wilwood Brakes, Minitubbed, Hotchkis Subframe Connectors, FIKSE FM5s
