Old 04-11-2015, 11:34 PM
frankv11's Avatar
frankv11 frankv11 is offline
Originally Posted by Justin@EntropyRad View Post
Thanks Vince!
Our harnesses and fan controllers really are sweet. Quite a few guys are running them on here, P-T, and Camaros.net
Thumbs up
For a sweet set up
Old 04-14-2015, 01:45 PM
Justin@EntropyRad Justin@EntropyRad is offline
Originally Posted by frankv11 View Post
Thumbs up
For a sweet set up
Ayy...Thank you sir!
Old 10-24-2015, 07:49 PM
00fxd's Avatar
00fxd 00fxd is offline
That looks like a very good fan controller. I am running a stock spec 195deg stat in in my dewitts rad-fan combo/lsx 6.0. in my early Corvette. That doesn't leave a lot of room for on and off. With my current sender the fan hits and stays on 'cuz the sender shuts off at 180. What temp does the stock ecm turn on the fan for a 6.0L? And what temp off? Do I need a controller that turns the fan on @ 200 and off at 196? I really like the 2 stage "on" idea too.
Thanks, Frank
Old 10-31-2015, 01:05 PM
cjsgarage cjsgarage is offline
You can adjust the turn on and off temps on the computer. Usually stock is just about 205 on 196 off. Something like that.
The PCM can control them if you like, or Entropy's set up is schweet. If you just need a harness and instructions, let me know and I'll send you some info and a harness if you need one.
I like wiring. No joke.
Old 10-31-2015, 07:36 PM
00fxd's Avatar
Thanks cj's. I would like my ecm to control my fan. Is the info and harness something you sell? I don't see it on your site ... I'm am enjoying looking through your site. You can PM me if you like or reply here...
I guess entropy didn't see my question.
Old 10-31-2015, 08:17 PM
randy randy is offline
Same here. I would love for my gmpp kit to control my ecu. Seems like the Entropy fan kit is the way to go. Can anyone post the instructions for the lsx entropy fan kit?
Old 11-02-2015, 12:33 AM
Randy, the gmpp computers can control fans just fine. I don't think they are set up PWM from the factory. The last one I did ran a pair of Derale fans. Controlled one each and you can even set it up to kick both on when it controls them separately.
00fxd,
pm sent
Old 11-02-2015, 05:07 PM
00fxd,
pm sent
You are right the ecu is not setup PWM from the factory. I guess its something that would be nice to have but not a must.
Old 11-03-2015, 01:04 PM
Randy,
It's really not a big deal. PWM is nice, yeah.. but fans turning on and off the good ol' standard way has been fine for me.. swap after swap after swap.
Some cars have such a large cooling system, we struggle to get them to even run at temp in the first place.. unless they're really beating on it. Autocross isn't that bad.. 60 seconds and the run is over..
Road race, time attack and road course? That could be 20 minutes to an hour. Some cars run multiple hours. That's when the BeezNeez of cooling systems might come into play.
Old 11-03-2015, 04:50 PM
Seems like the best way for me is to run the ecu wire to the outwore front headlight bulkhead for smooth wiring
