Old 04-07-2015, 06:09 PM
malo69 malo69 is offline
Default fan relay and wiring
just got my Griffin radiator with 2- 12" fans and need help with the relay and wiring . This is a 69 Camaro with a ls 2 I would like the computer to control them. what wires do I use for hi and low ? and where do I mount the relays . Thanks you
Old 04-07-2015, 08:21 PM
Vince@Meanstreets's Avatar
What harness are you running? Engine and vehicle?
Mount the relays close to your battery source. I like to mount them near the fans around the horn relay or junction on Chevy's.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 04-07-2015, 08:30 PM
Its a 69 Camaro with a ls2 (gto) harness is a after market with the normal deletes on ecm battery was relocated to the trunk
Old 04-07-2015, 10:37 PM
What brand engine harness or who put it together. Did it come with a relay block?
There should be a fan 1 and 2 wires from the PCM.
You can run a 10g wire from the starter BAT+ to a junction block or circuit breaker for the relays. Mount them up on the radiator support.
Dealer for
NEVER FORGET -11
Old 04-08-2015, 06:22 AM
dhutton dhutton is offline
Here is one option. Not the lowest cost but gives you dual speed fans and an option of A/C control.
http://shop.bp-automotive.com/Univer...rness-1022.htm
Don
Old 04-08-2015, 07:55 AM
Don
Pretty dang cheap if you ask me -- given what I pay for SPAL relays @ $34 a piece!
Old 04-08-2015, 09:55 AM
It is a good value. I bought one of these and it looks well made.
Don
Old 04-08-2015, 10:39 AM
well if your gonna roll the dollars might as well break out "the Player"! Or as Weld like to say the "da Playa"
http://www.entropyrad.com/wiring-harnesses.html
Everything that Uncle John needs.
Dealer for
NEVER FORGET -11
Old 04-08-2015, 07:45 PM
Thanks you guys for all your help Entropy has a real nice LSX SET UP its plug and play no need to run wires all over. Ill buy that set up I guess ill sell the 2 New relay kits that came with my Griffin radiator. Any body interested. Again THANK YOU FOR ALL YOUR HELP!!!! THE PEOPLE HERE ARE GREAT
Old 04-09-2015, 12:35 PM
Justin@EntropyRad Justin@EntropyRad is offline
Thanks Vince!
Our harnesses and fan controllers really are sweet. Quite a few guys are running them on here, P-T, and Camaros.net
