Old 06-23-2015, 10:04 PM
I think XRP carries something like the smooth hose, but not sure if that's it.
Old 06-25-2015, 09:12 PM
rallystyle rallystyle is offline
Swain any idea when they are going to release the kits again? i am about to get my car started and need a intake now. also are they not doing the heat shield anymore?
1970 El camino
1969 camaro
1996 civic
Old 06-26-2015, 10:15 AM
DKz Garage's Avatar
DKz Garage DKz Garage is offline
Thanks for the suggestions guys.... I ended up piecing together a system from Spectre Performance. Aluminum 4" tubes and couplers, etc...
Old 06-26-2015, 11:20 AM
Vega$69's Avatar
Vega$69 Vega$69 is offline
The 4" tube support they sell is great as well.
I had the whole kit on my last build and the shield would not work well with my aftermarket sub frame.
If you run the filter up behind the headlight with the 90* tube you do not need the shield.
Old 10-26-2015, 12:34 PM
Number1 Number1 is offline
Originally Posted by SlowProgress View Post
I am trying to figure out which hose system that Mark used in plumbing up the tank on Mayhem? It looks like a quality product and I want the black hose and fittings. I snooped around but could not figure it out. Anyone know for sure? There are a lot of choices out there now !
I believe those are tech afx hoses.
Old 01-30-2016, 11:36 PM
marathonboats marathonboats is offline
Banned
I agree with Built my own custom closeout / air box on the Pass side, and the entire filter is inside the fender
