Old 09-22-2015, 02:55 PM
Ah nice. Mine is DSE frame with engine setback mounts.
William
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 09-24-2015, 09:31 AM
andrewb70's Avatar
Originally Posted by 7firebird1 View Post
That looks sick!! Love the look of those Holley intakes. I would consider the Fast intake you have but mine is a 5.3.
I run a Holley Hi-Ram on a 5.3L...hole in hood!
Andrew
Old 09-24-2015, 07:15 PM
7firebird1's Avatar
7firebird1 7firebird1 is offline
Nice!!
Old 09-27-2015, 02:55 AM
T_Raven's Avatar
T_Raven T_Raven is offline
I guess I forgot the link to the intake comparison http://www.hotrod.com/features/1507-...ifolds-tested/
67, 68, 69 & 72 Firebirds, 79 TA, 89 GTA, 01 WS6, 68 Camaro, 68 Mustang, 54 GMC awd turbo, 67 GMC
Old 09-28-2015, 07:57 AM
7firebird1's Avatar
Very informative article. I really thought the Holley would dominate (no pun intended). Looks like Fast is the way to go. Why in the world does Edelbrock not use an LS style throttle body bolt configuration? Thanks for sharing the article!!
Old 09-28-2015, 08:27 AM
Vega$69's Avatar
Vega$69 Vega$69 is offline
The issue with the test is that different engines and cams will perform differently with different intakes. The results of this test does not mean that any particular intake is better for your engine.
Also meaningful is where in the rpm range the power is made and how you intend to drive the car. Then your tranny and rear end come into play.
Peak HP and Torque #s do not necessarily make a faster car.
Old 09-28-2015, 05:57 PM
7firebird1's Avatar
Good point! I'm just looking to get in the 500's and I'll be happy. I'm looking for something that looks good and performs well. I still might go with the Holley mid rise....if they start making them in black.
Old 09-28-2015, 06:33 PM
garickman garickman is offline
They do make a black ceramic coated mid-rise.
https://www.holley.com/products/ls_p...arts/300-135BK
https://www.holley.com/products/ls_p...arts/300-126BK
Greg
Old 09-29-2015, 06:40 AM
7firebird1's Avatar
Sweet!! Had no idea.
Old 12-14-2015, 06:04 AM
kttrucks's Avatar
kttrucks kttrucks is offline
I used the Mid-Ram and a 2 inch cowl hood and still had to trim the inner panel to fit. Used Holley engine mounts in the stock position, but a setback position would have helped bigtime. Sit your engine lower if possible. My (holley) swap pan has aabout 3/4 between the pan and subframe, so there's room to go lower, even with mine, but my buildplan was bolt-on stuff so I was a tad restricted.
looks cool though!
KT
PTFB, Viking, Holley Performance Products, BFGoodrich, Heatshield Products, Turbonetics, Hellion Turbo Systems,TCI, Dennys driveshafts, Eastwood, Preferredline Media, Summit Racing, Strange Engineering, Forgeline, TMI Products, DBR High Performance, Spectre Performance, Vintage Air, NPD, Digitails, Redline Lumtronix, Dakota Digital, Newport Engineering, Stage 8 fasteners, Industrial Depot, Brian Finch, Grant Salter, and many more Good friends with big hearts.
