Old 10-13-2015, 10:16 PM
I have a cooler in my radiator , I'm still going to use a 215 degree Improved Racing oil thermostat.
Old 10-14-2015, 06:35 AM
clill's Avatar
clill clill is offline
Originally Posted by Matt.A View Post
I'm thinking oil to water type heat exchanger/cooler, maybe?
And, add me to the list of people who think an oil cooler is a good idea.
That makes sense.. I just have a external cooler in front of the radiator.
Old 10-14-2015, 07:42 AM
Che70velle's Avatar
Again, watch your gauges. Quality engine oils are developed by chemists, and most require being 210-230 degrees to operate effectively, and efficiently.
You should at least have these numbers to allow the condensation that develops in your oil to evaporate. If not, the condensation (water) turns to an acid like mixture, that corrodes. Nothing wrong with a cooler...if you need one.
Thanks Dad!!
Old 10-14-2015, 10:21 PM
Panteracer's Avatar
Panteracer Panteracer is offline
Default Oil cooler
Sorry. Yes I have a water to oil cooler
that helps warm the engine oil when cold
Have not run an air to oil cooler since
I got the Pantera. Charlie is right the air
cooler works against you on a cold day
if trying to warm things up
Bob
Old 10-15-2015, 08:52 PM
Solid LT1 Solid LT1 is offline
From my C5 Z06 autocross days......you will see a 15-20 degree oil temp spike from extended high RPM operation on a 40-60 second autocross lap in a LS motor......run the cooler!
Old 10-16-2015, 08:41 AM
On a STREET / DD car -- if I ran an oil cooler (air to oil version) I'd run a thermostat in the system to make certain the oil gets up to temp. Running the oil too cool could lead to moisture building up. I don't know if you'd need that in a water to oil cooler as then the temp would be more controlled.
Like Charlie said -- we have to tape over our air to oil coolers at the track to get some heat in the system. But those are race/track cars... and are driven hard for 20 minute periods much of which is at WOT. Imagine now just running around on the street... and all the stopping etc that doesn't create any heat.
Old 10-16-2015, 10:19 AM
spacepirate spacepirate is offline
Thanks for all the advice guys.
