Old 10-12-2015, 09:26 PM
spacepirate spacepirate is offline
Default Should I run an oil cooler?
I have an LS3 with a stage 1 Mast Motorsports cam and Mast oil pan. I was curious if I should run an oil cooler? My plan is to daily drive it and try my hand at the occasional autox.
Old 10-12-2015, 09:48 PM
Yes...and my favorite answer, wouldn't do any harm now would it?!
Old 10-12-2015, 10:19 PM
Sieg's Avatar
Sieg Sieg is offline
Run an oil temp gauge and let that make the decision for you.
Old 10-13-2015, 05:18 AM
Che70velle's Avatar
Stock LS3? I wouldn't bother with it. GM did a great job with temp control. Hot oil is your friend (to a degree...pun intended), and you certainly don't want to cool the oil unnecessarily. As Sieg suggested, let you gauge make this decision for you. Just because you can, doesn't mean you should.
Thanks Dad!!
Old 10-13-2015, 07:24 AM
Rod P's Avatar
Rod P Rod P is offline
if your going to autocross it..... oil cooler and power steering cooler....at the very least.....
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 10-13-2015, 11:25 AM
Thanks guys.
Old 10-13-2015, 12:00 PM
Panteracer's Avatar
Panteracer Panteracer is offline
Default Oil Cooler
One thing I saw when I put the oil Cooler on it also
helps warm the engine up quicker..... You are on grid
at an Autocross on a cold morning and the cooler actually
helps put some heat in the engine before your first run
I always worry about hammering it before the oil actually gets
warm.. believe me it takes a little while if you watch that gauge
Bob
Old 10-13-2015, 03:41 PM
Chad-1stGen's Avatar
Chad-1stGen Chad-1stGen is offline
Agree with this.
If you do run an oil cooler make sure you get a quality thermostat to ensure minimum heat in the oil.
Autocross and Track blog
Lots of autocross & track day videos of my car: https://www.youtube.com/user/TheDude023
Old 10-13-2015, 07:57 PM
clill's Avatar
clill clill is offline
Bob
For the life of me I can't figure out how the oil cooler helps warm the engine up on a cold morning. On my track car I have to put tape over the front of the cooler on cold mornings so the cold air doesn't keep cooling the oil.
Old 10-13-2015, 08:43 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
I'm thinking oil to water type heat exchanger/cooler, maybe?
And, add me to the list of people who think an oil cooler is a good idea.
