Old 07-08-2006, 05:32 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Default DSE Subframe Press Release with pictures
Detroit Speed and Engineering’s all new front subframe is a bolt in replacement for the original stock subframe and improves the handling and ride quality by utilizing DSE’s unique suspension geometry. It is the only subframe in the aftermarket industry with hydroformed frame rails. The hydroformed frame rails feature strength and stiffness, relatively low weight, and precise quality and repeatability. Hydroforming preserves the steel’s strength and stiffness because it is performed at low temperatures, unlike traditional high temperature processes which decrease
material strength.
The subframe utilizes a coilover shock/spring, rack and pinion steering, and splined sway bar. A 10” wide wheel can be packaged and the subframe comes assembled as an entire system. Both main and secondary crossmembers are stamped for structural rigidity. SBC, BBC, and LSX engines have been designed into this subframe.
Detroit Speed and Engineering, Inc. is located in Mooresville, North Carolina. The company provides products and services to transform a vintage muscle car into an all-around versatile vehicle. In addition to design and fabrication services, the company manufactures a line of components to bring muscle cars into the new millennium. Detroit Speed and Engineering, Inc. has been recognized for its engineering and attention to detail. For more information, contact Detroit Speed and Engineering, Inc. at 704-662-3272 or on their website at www.detroitspeed.com.
THE ONLY HYDROFORMED FRAME IN THE AFTERMARKET!
The hydroformed frame features great strength and stiffness, relatively low weight and precise quality by replacing the stamping process.
DSE exclusive suspension geometry for superior ride and handling
Specifically designed with power rack and pinion steering
Utilizes a splined sway bar
Hydroform subframe is a direct bolt-in, decreasing installation time
Accepts SBC, BBC, or LSX engines
Design can accommodate a 10” wide front wheel
Coilover shocks/springs allow spring rate tuning and ride height adjustment
My LS7 69 Camaro
