Old 01-19-2016, 09:35 PM
MtotheIKEo MtotheIKEo is offline
Originally Posted by will69camaro View Post
Can you find me a Tee that's 1/8" NPT male to two 1/8" NPT female in stainless? All i can find is NOS brass one. Need it for oil feed for turbo/sensor placement on my new Mast pan...
This is the brass fitting i want in stainless...
http://www.summitracing.com/parts/nos-16775nos
William
Does it have to be that configuration? Parker sells stainless fittings of all kinds.
https://www.grainger.com/product/PAR...Code=P2IDP2PCP
Old 01-20-2016, 04:24 AM
69hugger's Avatar
69hugger 69hugger is offline
William
Easy peasy!
http://www.stainlesssteelfittings.co..._p/ss-5602.htm
(Check out the price of the large ones)
Like I said, I found everything damn fitting on earth EXCEPT the inverted flare I need!
Bill
Bill
'69 Camaro / 534 BBC / DSE Built
'67 C10 / LS-3 w/Magnuson / Roadster Shop Chassis (SOLD)
'71 Blazer / LT4 / 8L90 / Roadster Shop Chassis / Ride Tech Air Susp.
Old 01-20-2016, 11:53 AM
Excellent, exactly what I was looking for. Needs to be that configuration cause there is no room above for the tee to be facing the opposite way.
William
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 01-20-2016, 01:14 PM
andrewb70's Avatar
Wilwood sells a prop valve that has 3/8" inverted flare holes so you don't need those ridiculous NPT adapters.
Andrew
Old 01-20-2016, 01:46 PM
dontlifttoshift's Avatar
Wilwood part number 260-10922
Donny
Old 01-20-2016, 03:34 PM
69hugger's Avatar
Andrew
Thanks Andrew & Donny! I never thought of that. I bet that is no more 'pensive than a couple of the unobtanium adapters I'm after.
Looks like I will soon have a couple of Baer prop valves available.
Thanks again guys!
Bill
Bill
