Old 02-19-2016, 09:38 PM
snappytravis's Avatar
Default Ez clip
I ordered everything from hose warehouse, The only problem is they make a ton of different ones.. you can buy clip kits as well, and the pliers off amazon. I had crimp hoses on everything and changed everything. I installed the high and low pressure ports on the bulkhead and one on the drier. Then I just have regular 90s on the compressor with no valve. It looks half way decent. Good luck
Old 02-20-2016, 07:56 AM
wiedemab's Avatar
wiedemab wiedemab is offline
Kevin -I may have misunderstood. I just bought the crimp tool and cage clips kit/box. I bought all of my fittings individually.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 02-21-2016, 06:57 AM
kevin_l's Avatar
kevin_l kevin_l is offline
This sounds like my best option at this point.
Ok, yeah I thought you meant the va ez clip kit with hoses. So you sourced the hose and fittings separate, and bought the clip kit. Thanks for the clarification. I noticed they sell serveral fittings of each size. I'll have to see what the differences are.
