Old 12-22-2016, 07:03 PM
JKnight JKnight is offline
I put it up the inside of the firewall too, but the header/heel issue was a better example of how well it works. Others that buy better headers won't need the floorpan covered, which is good cause it's pretty thick.
Old 01-23-2017, 02:16 PM
Doug1's Avatar
Doug1 Doug1 is offline
Originally Posted by JKnight View Post
I used a second skin audio product. Heat wave maybe? Worked like a champ. My right heel used to get hot through my shoe from the collector and it totally cured that. Foil on both sides, jute-like material in the middle.
Yep: http://store.secondskinaudio.com/the...sulation-mats/
Do you recall how much of it you used? It comes in sheets 4'x6'
Old 03-13-2017, 02:11 PM
simon455's Avatar
simon455 simon455 is offline
Neoprene works very well under the carpet and at firewall. Jute is also great thermo isolation, just looks old school and hard to come by now days. There are neoprene rolls even with one side shielded with tin foil and adhesive on the other. Just gotta look at different surplus places and suppliers...
69 drag radial firebird (sold)
72 pro touring gran torino (dad's)
68 camaro ss pro touring pending project
2002 dallara ir-2
c5 rag top with z06 stuff
300 tire custom night rod
2014 viper TA
Old 03-13-2017, 08:48 PM
Sorry, just saw this question. It's been a while so I don't remember exactly. I don't think it was more than one sheet because I bought a Scrap the shop had laying around. 4x6' covers a big area on these smallish cars. If I pull the carpet out I'll let you know for sure. I was focused on the drivers pedal box area and the firewall directly behind/above the engine/trans.
The Following User Says Thank You to JKnight For This Useful Post:
Ri10 (11-06-2018)
  #15
Old 08-24-2017, 11:50 PM
LateralJeaz's Avatar
LateralJeaz LateralJeaz is offline
Can I revive this to see if anyone has delved into the aerogel option? Scientifically it has some of the most impressive heat dispersing properties. The C7 uses it on the tunnel
