Old 08-07-2006, 12:32 AM
Vince@Meanstreets's Avatar
Originally Posted by Dodgenut64
so a float or baffle is a must then? what does the float do? im green, real green at all this stuff.
Yes, it is a must. float is the tubular white object (near center of picture)...A baffle would be a shield or dam that is welded to the bottom of the tank or part of the unit itself, that basically retains fuel or keeps the fuel around the pick up screen (white object lower right corner as pictured) during acceleration,braking or turning.
Old 08-07-2006, 09:46 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
the pic above was from the artical. so a float or baffle is a must then? what does the float do? im green, real green at all this stuff.
Float tells your fuel gauge how much fuel is in the tank. So I guess it's not a must, if you're not worried about that, .
