Old 03-03-2019, 12:04 PM
Tony V Tony V is offline
I switched to a Ron Davis with in integrated Oil and P/S cooler and couldn't be happier....racing in 90+ temps never approaches "hot". Nice workmanship....
Old 09-24-2019, 10:30 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
I've had a Ron Davis before and it was great. Wouldn't hesitate to use them again. It cooled very well and efficiently which says a lot due to the fact I live in Texas where the summer temps are the equivalent to hell. However, I just ordered an AutoRad last week because I wanted the cool Core support and ordered an intercooler too with the A/C condenser and love how the mount everything all together nicely. Anyone got any stories...good, bad or indifferent about their AutoRad.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 10-05-2019, 09:55 AM
pannetron's Avatar
pannetron pannetron is offline
The Griffin I installed in my '66 Chevelle w/ LSA started leaking from multiple places after just two years. Just installed an AFCO radiator to replace it. The fan shroud on the Griffin was a better design but the AFCO radiator is much more efficient at shedding heat.
Old 01-01-2020, 01:34 PM
cpd004's Avatar
cpd004 cpd004 is offline
My Griffin is leaking. This is the second one in 4 years with minimal driving. The first was replaced by Summit as a warranty claim. Now, I'm back to square one.
1971 Firebird
2017 SS
Old 10-05-2020, 10:20 PM
MtotheIKEo MtotheIKEo is offline
I'm in the same boat with Griffin, mine just started leaking at the upper corner where the tubes are bonded to the end tank. Hopefully Summit will help out, I have had it installed for just over 2 years.
Old 10-07-2020, 08:47 AM
Jimmy Sean's Avatar
Jimmy Sean Jimmy Sean is offline
I went through three Griffin radiators in 4 years. I'll never buy another nor recommend one. I replaced it with a triple pass from Jegs. So far so good but time will tell.
1969 Firebird, L-76 LS2, T56, Speed Tech Torque Arm, Build Thread
Instagram @jimmysean69
Old 08-12-2021, 06:48 PM
Ttype455 Ttype455 is offline
Originally Posted by patriot68 View Post
Entropy radiators
I’ve done a lot of researching on radiators. That’s funny you mentioned entropy that you pointed out. I was planning on going with them also. I want USA made.
It seems a lot of companies like griffin are going overseas, and I’m reading “a lot ”of bad reviews on them. But I guess they used to be a lot better years ago. Seems quality has really gone down.
Old 08-13-2021, 05:18 PM
joeko23 joeko23 is offline
Entropy has a lifetime warranty. I got for my 69 LSA project. It’s made very well and the fans seem to be very powerful.
My Very Ambitious 69 Camaro Build
https://www.pro-touring.com/threads/...d-0-Fab-Skills
Old 10-01-2021, 12:22 PM
57vette 57vette is offline
Using a Cold Case in my 461 BBC 69 Camaro. The radiator brackets locate the radiator 5/8" further back than the stock radiator, seems to be the only complaint many users have had. I had my brackets cut off and re-welded same as factory radiators. Otherwise really nice quality and customer support. It has two tubes that are 1-1/4" which is pretty impressive.
Works fine but I suspect my fans could be more powerful.-Mike
Old 10-01-2021, 12:35 PM
partsguy57 partsguy57 is offline
Wizard cooling..
Sent from my SM-G965U using Tapatalk
