Old 09-17-2017, 10:41 AM
vstol vstol is offline
Originally Posted by raustinss View Post
Why can't you just leave it and remember to divide by two eveytime you look at it
Lmao
I would need a 14K Tach
Old 09-17-2017, 01:22 PM
found the directions to set the pins now lets see if it works
Old 09-17-2017, 02:14 PM
gnx7's Avatar
gnx7 gnx7 is offline
When trying to adapt to factory gauges on the RX-7 we use one from Dakota Digital. http://www.dakotadigital.com/index.c...126/prd126.htm
Speedhut also makes kick ass gauges that are GPS based for speedo!
Old 09-17-2017, 04:48 PM
Fixed it just had to change the Tach back to 8 cylinders. Thanks for your help.
Old 09-17-2017, 05:26 PM
Shoulda called me first!
Glad that worked!!!
Old 09-18-2017, 07:30 AM
randy randy is offline
when i had mine set to 8 cylinder it wouldnt read past 5k rpms. I had to switch mine to 4 cylinder and use a pull up resistor. Resistor on the power wire going to the gauges to the signal wire going to the tach.
Old 09-18-2017, 03:04 PM
I tried that before getting the resistor but it did not work.
