Old 09-16-2017, 11:01 AM
vstol vstol is offline
Default Autometer tach reads double
I have a LS-3/427 with an Autometer tach and the Autometer LS adapter for the tac (9117/9123) and the tach shows the idle to be 1900 when in fact it is 980. What did I miss? I thought I had set the tach right I believe it was 4 cylinders and it is a huge effort to get it back out so I would like to avoid that. thanks
Last edited by vstol; 09-17-2017 at 04:57 AM. Reason: change the thread title to Autometer tach reads double
Old 09-16-2017, 11:34 AM
I'm laughing at this because if it's set to 4 cylinders and getting a signal from 8 then sure -- it would read double.... But the LS standard output is a 4 pulse - but the tach adaptor kicks it to 8.... So my guess is --- you needed to set the tach up for 8 cylinders - and allow the adaptor to do it's job.
You might need to read this "fix" twice to understand it -- I did. Basically it's an issue of you used the adaptor - thus outputting a 8 cylinder signal and the tach is set up (per what you said) to read 4 cylinders....
https://www.autometer.com/resources/...faq_view/id/77
Old 09-16-2017, 11:42 AM
Greg SOB, totally agree and what is confusing I did not reread the FAQ that you sent.. actually I read it several times before I set it up and probably had a senior moment. I will give it a go as it will be some ass pain getting to it. Thanks
Old 09-16-2017, 11:50 AM
I hope that's all it is -- but it made sense that using the ADAPTOR giving the TACH an 8 cylinder signal -- that it would read double with it (the tach) set on 4 cylinders.
My question was - in that case - why do you need the adaptor - if you could just set up the tach with 4 cylinders selected..... That's why I read it twice - to see if I missed something there...
Hope that's all it is - but it looks like that's the mismatch.
Old 09-16-2017, 12:01 PM
The adapter made it plug and play. I tried it the other way but no luck. Now I am trying to find how to set up the tach (pins) for 8 cylinders in the back of the tach. I do not believe they make them that way anymore since this build has gone on way to long.
Old 09-16-2017, 07:46 PM
I'm going to subscribe to this because senior moments have become a big part of my life now a days. Now what was I going to do with this????
Old 09-16-2017, 07:51 PM
Wait! What were we talking about???
Old 09-16-2017, 08:18 PM
Exactly!
Old 09-17-2017, 04:17 AM
Setting the tach to 8 cylinders. I have the pins in the back to do that. Put a yellow sticky where the beer is to remind you of the task.
Old 09-17-2017, 06:13 AM
Why can't you just leave it and remember to divide by two eveytime you look at it
Lmao
