Old 01-19-2019, 08:45 PM
Doug1's Avatar
Doug1 Doug1 is offline
Originally Posted by Musclerodz View Post
I use the bands. clamps are ugly.
Agreed. Looks like I need to place an order for some new hose and bands. Too bad, that was a lot of expensive hose that's now trash. At least I learned a valuable lesson without burning the car down. Aeromotive shows their push lock hose is suited for fuel in it's brochures. I bought the hose because I bought their fittings. So off it comes and new hoses will be built before it drives anywhere again.
That's 11 hoses in my fuel plumbing. All under 3 feet or so but still a lot of hose. I might buy the Kool Tool push on hose kit to do that many hoses again. I had a sore shoulder last time trying to get the hoses on all the way. Even with lube that Aeromotive hose is stiff.
Old 01-19-2019, 08:47 PM
Musclerodz's Avatar
The gates hose is real easy to push on compared to some other brands. I have tried some pushlok that was so tight, I gave up.
Mike Redpath
Musclerodz & Customz
facebook page
Old 01-19-2019, 08:49 PM
cjsgarage cjsgarage is offline
If you run hardline except for the flex for tank drop-down and from firewall to block, you'll save on serviceable pieces.
I like wiring. No joke.
The Following User Says Thank You to cjsgarage For This Useful Post:
camcojb (01-19-2019)
  #14
Old 01-19-2019, 09:09 PM
Doug1's Avatar
from my iPhone using Tapatalk
Pretty much what I do.
1 from rear bulkhead return fitting in tank
1 from in pump in tank to fuel filter
1 from fuel filter to rear bulkhead pressure line
1 from front pressure bulkead fitting to filter
1 from filter to Y adapter to split to fuel rails
2 from Y adapter to fuel rails
2 return lines from fuel rails to regulator
1 from regulator return to return bulkhead
Untitled by by [url=https://www.flickr.com/photos/159188510@N03/],
Untitled by [url=https://www.flickr.com/photos/159188510@N03/]
Old 01-19-2019, 09:15 PM
Just saying, if you make the fuel-rails-to-y a hardline, then you only have the soft line from
Y to hardline-at-firewall.
In total, any car I build is usually only 4-6ft total of soft line. So there's only ever 2 lines and 4 fittings total for soft line. Makes it nice for future servicing—only two lines to replace if they're worn.
Old 01-19-2019, 09:18 PM
Doug1's Avatar
Makes sense. I'll plan it that way next build!
Old 01-19-2019, 09:22 PM
Doug1's Avatar
Thanks. I'll look for the Gates stuff.
Otherwise I'd have to buy this from Kool Tools.... If I did this professionally, I'd buy this in a minute!
https://www.youtube.com/watch?v=wqDFjUk-dmc
Of course, my motto is "there's no job worth doing that doesn't require a new tool" so.... I might buy it anyway. LMAO
Old 01-19-2019, 09:24 PM
The Kool Tools has heaps of bad reviews, I've heard. Anyone have any experience with install tools?
Old 01-19-2019, 09:29 PM
Doug1's Avatar
I see from your tag you like wiring. PM me if you have done any SSR work. I did quite a bit in this build and it was interesting
Old 01-20-2019, 04:05 AM
dhutton dhutton is offline
I have one of those Kool Tools. Works fine for what I use it for.
Don
