Old 03-26-2020, 08:05 AM
billohio billohio is offline
I figured out my situation recently. The CTS-V used a different tail shaft housing compared to the ZL1. Both are MG-9 but different tail shaft housing. I was concerned on what I had that is wasnt the MG-9 but it had the same serial numbers as the engine. That is the difference and the need for 2 mounts.
Old 03-26-2020, 08:06 AM
NickBurns NickBurns is offline
Ahh I forgot about that option as well. Mine is from Holden. What mount did you go with ?
Nick's son was last seen finishing up his 1968 Pro Touring Camaro
1968 Pro touring Camaro
ALL DSE Suspension
2017 6.2L made of steel balls
Old 03-27-2020, 10:02 AM
I have hooker motor mounts and got the blackheart crossmember and the poly mount. I am getting ready to see how it fits but may need to modify the crossmember. I never found much info on how this will fit. I may try and see if I can reuse the bracket that bolts to the transmission or make something
