Old 09-18-2020, 03:03 AM
paulk68 paulk68 is offline
Originally Posted by F'in mine View Post
I ended up adding a little extra insulation around some critical areas where exhaust heat from headers, intermediate pipes and mufflers are routed as well as the back seat divider.
https://www.thermotec.com/products/s...hermo-guard-fr
I found that the extra barrier helped fill in the carpet better.
To punch around bolt holes......take a piece of thin diameter pipe 3/4"-1", grind a bevel around the tubing then hammer at areas that you need to fasten stuff to, makes a nice clean open area.
that looks great! will probably do the same. did you use the spray adhesive to install it?
Old 09-18-2020, 10:27 AM
F'in mine's Avatar
F'in mine F'in mine is offline
No I just used some thin 2 way tape to hold it in place. Didn't want to fight with it if I ever have to remove it.
1969 Camaro SSRS
Simon
Old 09-19-2020, 05:46 AM
Great Idea!
Old 09-26-2020, 08:19 AM
jarhead's Avatar
jarhead jarhead is offline
Paul, is it hard to put it inside the doors? I was under the impression this stuff sticks and there is no chance to peel or move it when it does.
joe
Semper Fi
My 68 Torino
Old 09-27-2020, 02:39 AM
No it was not to difficult to get it inside the doors. it is sticky but you can adjust it if needed. I would only peel half the paper backing off until I got it placed where I wanted then would pull the rest once it was set. Once you roll it down I would not want to try to move it but I am really glad I did the doors they close so much nicer.
The Following User Says Thank You to paulk68 For This Useful Post:
jarhead (09-27-2020)
