Old 10-04-2006, 04:07 PM
Scotch Scotch is offline
Originally Posted by rocketman
I don't know how you guys get away with mixing motor mounts like that,I have seen alot of broken blocks because of mixing mount motors.
Really? I've never seen a single one. By having at least one rubber mount on the passenger side, all the vibrations have a place to go. The solid on the driver's side doesn't move at all, and it can't break.
I've never seen a block break because of this. With all solid mounts, I've seen the stock block bosses break in extreme applications, but not with a mix.
Interesting...
~SP~
Old 10-04-2006, 08:11 PM
TravisB TravisB is offline
We mount most of ours solid.......Motor and trans!
Kenny Davis Hot Rods
Old 10-04-2006, 09:55 PM
tyoneal's Avatar
tyoneal tyoneal is offline
Mount it with good poly or rubber mounts, then chain the drivers side. Driving around all is smooth and it won't vibrate you to death.
When you decide to get down on it, the chain will do it's job and you won't have to worry about breaking a mount.
I ran a BBC with 650 hp. It worked like a champ and it is an easy AND inexpensive way to solve your problem.
tyoneal
Old 10-05-2006, 08:06 AM
nitrorocket's Avatar
Chaining is a horrible idea, that would snap a block instantly off the trans brake for sure! If it ever gets a hard shock it could break the block, for sure if it is an aluminum block.
Twin Turbo LS1 '71 Chevelle
1000 hp 93 octane street car
6 speed
