Old 06-10-2023, 04:25 PM
camcojb camcojb is online now
I've seen rust like that on MSD's even in Sacramento which is low humidity.
Old 06-11-2023, 07:12 PM
DRJDVM's '69's Avatar
Yeah mine did that too.... think it's just condensation from the heat. I found it when I went to EFI and replaced it with the hyperspark set up. My car was running fine before that, I just found it when I did the swap.
Back in the day I remember guys talking about drilling a small hole in the cap to let out the moisture that would tend to build inside the cap
Old 06-11-2023, 07:31 PM
Originally Posted by thedugan View Post
Wow. What would cause all of that rust?
MSD stuff is made for weekend warriors in performance applications. Their caps wear quickly too. OK for low mileage applications. Not so much for a daily driver or longevity. JMO
Old 06-12-2023, 05:03 AM
OLDFLM's Avatar
OLDFLM OLDFLM is offline
Default MSD 6 BTM
Glad you got it back up and running!
Food for thought:
When I had a Paxton Novi on my Fox body Mustang years ago I ran a MSD BTM so that it would back off timing as boost increased. I was spinning it up to 10-12lbs of boost with that set up without issue...
Another thing you could look into is a dual sync distributor so that your ECU is controlling the timing and the air/fuel ratio.
Ty Ingle, USAF Retired
FREEDOMBIRD
The Following User Says Thank You to OLDFLM For This Useful Post:
camcojb (06-12-2023)
  #15
Old 06-12-2023, 09:11 AM
mdprovee's Avatar
mdprovee mdprovee is offline
Yea not sure why it rusted either. Something I will keep on eye on now.
Thanks I will look into the MSD 6 BTM.
Mike
