Old 03-21-2024, 09:33 AM
colorado80439 colorado80439 is offline
What happened to the 69 LS7 build? Wasn't it in paint late last year?
OMG the 69 it's still in paint, should be sprayed in the next week or 2, it's been in paint for a year now, there's only 1 paint and body guy (who is excellent) at the shop and he keeps getting pulled off my car for other small projects.
I've just started a 67 now leaning toward a RS fast track chassis with an LS9. Currently discussing fitment with Roadster shop, as always issues and compromise w/ engine clearance, FEAD systems, track width, tire, wheel size and set back
The Following 2 Users Say Thank You to colorado80439 For This Useful Post:
camcojb (03-21-2024), fleet (03-22-2024)
Old 03-21-2024, 09:40 AM
Originally Posted by srode1 View Post
As far as fitment the LT4 high pressure pump will mean you probably need to modify the firewall for clearance, for the pump and the electrical connections. That's the price of direct injection vs port injection. I'm sure you've read the other technical differences and that the LT4 has more torque earlier making for a flatter power curve too which is an advantage in any application IMHO. The wiring on the LT4 isn't really complicated, just plug stuff in and it works and it's gone in lots of cars so there's plenty of information on front runners.
Thanks for the insight, I've enjoyed watching your build
The Following User Says Thank You to colorado80439 For This Useful Post:
  #13
Old 03-21-2024, 09:48 AM
Thumbs up
Originally Posted by rpol78 View Post
My understanding is you have more ECM options with the LS and more options for making changes. I do like the LT4/LT5 engine with the direct injection. It just depends on what you want to do in the future.
Hmmm... Makes me wonder what my LS 396 engine is worth (LS9 block/LS9 CNC heads, Callies Magnum custom crank, Callies Ultra rods, JE custom pistons, Kong 2650).
FWIW - This is going in a '67 Chevelle.
Very nice, Kong 2650 LSA blower on an LS9, with a dedicated SC pulley who's front runner is that?
  #14
Old 03-21-2024, 07:42 PM
rpol78 rpol78 is offline
Thx, It's the GM modified LSA accessory drive 19417908. It has the same spacing as the corvette accessory drive with the LSA SC pieces added to it. Unfortunately it doesn't look like it's available as a kit any more.
I ended up having to use the Holley A/C compressor mount with a Sanden SD7B10 since I couldn't get a GM compressor to clear the main cross member. I'm still trying to work out the A/C lines on it.
The Following 2 Users Say Thank You to rpol78 For This Useful Post:
  #15
Old 03-24-2024, 06:29 PM
Ended up going this direction
camcojb (03-24-2024)
