3kidsnotime,
I just came in from doing what you asked. I backed the bolts out so that there was no pressure. The tranny came back only enought for me to just slip my fingernail in between the trans case and the alum. ring.
I then dropped it done off jacks and in 1st with the clutch depressed I hit the starter and it surged forward and continued to when the engine hit. I killed the engine and tightend all bolts back up. Does this confirm the problem is not a input bind issue? Do you have any other ideas for me to look at? I appreciate the ideas.
I looked in the bell "window" and the slave/TOB is right against the fingers of the pressure plate as it sits with the clutch depressed. Is this correct, or should it be backed off to some degree?
"Edit"
I just got a link on a Mcleod clutch install in an LS1/T56. The install shows shims used to allow for the correct TOB travel to disengage the clutch. Neither my clutch nor my pressure plate came with any shims so I don't know if they were left out or must be bought separate. In any case, I may have to pull everthing out and change the shim thickness.
Here is the link to the install showing the shims:
http://www.installuniversity.com/ins...ch_install.htm
Kerry
