Old 05-12-2005, 05:00 PM
Y-TRY Y-TRY is offline
Default Two cents...
I chose the TKO over a 6-speed also.
I had 3.89's with my 5-speed and highway driving was very comfortable with one overdrive. But final drive wasn't an issue, it was 1st gear. The 5 and 6 speed transmissions share the same 1st gear: 3.27:1. After my first drive I immediately yanked the 3.89's and swapped in 3.25's.
Frankly, the combination of a 3.27 1st gear and 3.89 rear gears is bad. Read my "Driving Impressions" thread. With the engine you speak of you won't need the torque mulitplication of a steep gear, anyway. So why suffer with an ultra-granny first gear?
IMHO, putting in a rear gear that matches the 3.27 first gear would result in a 6th gear cruise rpm just above idle, and that's just no fun.
Old 05-12-2005, 06:19 PM
USAZR1's Avatar
USAZR1 USAZR1 is offline
Correct me if I'm wrong here but the only T56 with a 3.27 first gear was 1993? Later years have a taller first gear. My Viper T56 has a 2.66 first gear.
Also,trying to run a 3.25 rear gear with a 6spd might be a little frustrating as the final drive ratio would be so tall,you would rarely be able to use 6th gear.
FWIW,I'm running a 4.11 cog and am only turning 2,000rpm in 6th gear at 70mph,with 26" tall tires (335/35/17 Kumhos).
Clint Hooper
Clint's 70 El Camino restomod Sold
Clint's 69 Elky Protourer Sold
Old 05-13-2005, 09:29 AM
93Polo 93Polo is offline
The Z06 and GTO also come with a 2.97
http://www.rjsmith.com/z06.html
http://www.newagegto.com/05GTO.html
Some 93 f-bodies came with a 3.36
http://www.f-body.org/oldfaq/html/faq/index.html
Old 05-13-2005, 09:42 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
I know it can't be done, but not sure why.
Why can't you put a late model one piece rear main flywheel, on a old style two piece rear main crank?
Old 05-13-2005, 09:56 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Mark, this isn't my strong suit, but I believe a 2 piece rear main seal crank has a 2.5" register and a 1 piece rear main seal crank has a 2" register.
My LS7 69 Camaro
Old 05-17-2005, 02:51 PM
I stand corrected. For some reason I always thought they had the same steep 1st gear of 3.27:1.
Well, with that in mind, I guess you can go a bit steeper in the rear with the 6-speed than I thought. Have fun!!
