Old 02-08-2007, 03:04 AM
We sell a lot of the Rick's tanks with A1000 in them. We run that set up on Project Prodigy.
Frank Serafine
Old 02-08-2007, 05:42 PM
4mm 4mm is offline
Originally Posted by Ricochet
I just ordered my tank from Ricks and Hector, or should I say I, went back and fourth and which pump set up to go with. I'm running a mild EFI Big Block that is just at the 600 HP mark. The A1000 is to much for me (although with a controller would work fine) then I went back and fourth on the Walboro's or he suggested the Aeromotive 11106 inside the tank.
Brent
How is the noise level with it in the tank? I have heard the A1000 and it was a bit too much for me.
Old 02-08-2007, 06:53 PM
With the top down, when you turn on the key you know it is on. Which I kinda like. Once we fire the car, it is not heard.
Frank Serafine
Old 02-11-2007, 01:27 AM
ss dave ss dave is offline
Update on the fuel pump, the Walbro pump is a hi-pressure 255l/hr pump rated conservatively at 640hp NA. This should be adequate for my application, and just as important keep it simple. The Aeromotive A1000 pumps that Rick's also place in their tanks work great for higher HP set-ups, but may require a few more additions such as a BG heat sink.
Old 02-11-2007, 03:24 AM
Hello Dave! Good update,thanks for the info.
63 Z06
Old 02-12-2007, 01:08 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Don't know at this point. The tank is still being built & at my rate might be in the car this decade!!
Brent
