Old 07-15-2008, 11:44 PM
Originally Posted by Stuart Adams View Post
Part from MSD ordered. Distributorless ignition driver. Once its in and running I'll follow up.
Thanks Stuart!!! Is your racapak version wich displays all info at the same time ? Like speed , rpms, temperatures? Or is it neccesary to choose one ?
63 Z06
Old 07-16-2008, 05:28 AM
Lateral-g Moderator
Its the new IQ3. RPM, Speed, water, oil, fuel, all at once. Toggle to get volts. Pretty slick little unit. Plus we have low oil light programmed, and high water temp warining light also programmed just to be safe. Also a light for engine codes that may come up, like a check engine light in a new car.
Old 07-16-2008, 12:37 PM
Hello Stuart, one question just to be sure. Are you using stock gm MEFI4 pcm with the IQ3 Racepak ?
63 Z06
Old 07-16-2008, 01:36 PM
Lateral-g Moderator
Yes.
Old 07-16-2008, 11:07 PM
Yes.
63 Z06
